Ana içeriğe geç
OLPC XO-4 Touch Touchpad Controller Replacement
Neye ihtiyacın var
  1. OLPC XO-4 Touch Touchpad Controller Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop upside-down, with the handle facing away from you.
    FixBot'a Sor
    Yorum Ekle
  2. OLPC XO-4 Touch Touchpad Controller Replacement: adım 2, 2 resimden 1. OLPC XO-4 Touch Touchpad Controller Replacement: adım 2, 2 resimden 2.
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
    FixBot'a Sor
    Yorum Ekle
  3. OLPC XO-4 Touch Touchpad Controller Replacement: adım 3, 2 resimden 1. OLPC XO-4 Touch Touchpad Controller Replacement: adım 3, 2 resimden 2.
    • Lift up on the middle of the battery to remove it from the device.
    FixBot'a Sor
    Yorum Ekle
  4. OLPC XO-4 Touch Touchpad Controller Replacement, Keyboard: adım 4, 2 resimden 1. OLPC XO-4 Touch Touchpad Controller Replacement, Keyboard: adım 4, 2 resimden 2.
    • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
    FixBot'a Sor
    Yorum Ekle
  5. OLPC XO-4 Touch Touchpad Controller Replacement: adım 5, 3 resimden 1. OLPC XO-4 Touch Touchpad Controller Replacement: adım 5, 3 resimden 2. OLPC XO-4 Touch Touchpad Controller Replacement: adım 5, 3 resimden 3.
    • Flip the laptop over to its normal position.
    • Lift the two antennas on both sides to unlock the screen.
    • Open the laptop.
    FixBot'a Sor
    Yorum Ekle
  6. OLPC XO-4 Touch Touchpad Controller Replacement: adım 6, 2 resimden 1. OLPC XO-4 Touch Touchpad Controller Replacement: adım 6, 2 resimden 2.
    • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
    • Gently lift up on the back of the keyboard.
    • Pull the keyboard up far enough to expose the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  7. OLPC XO-4 Touch Touchpad Controller Replacement: adım 7, 2 resimden 1. OLPC XO-4 Touch Touchpad Controller Replacement: adım 7, 2 resimden 2.
    • Gently lift up on the black connector to release the ribbon cable.
    • Gently pull the blue plastic tab up and away from the black connector.
    • Remove the keyboard from the laptop.
    FixBot'a Sor
    Yorum Ekle
  8. OLPC XO-4 Touch Touchpad Controller Replacement, Lower Case: adım 8, 2 resimden 1. OLPC XO-4 Touch Touchpad Controller Replacement, Lower Case: adım 8, 2 resimden 2.
    • Close and flip the laptop over so you are looking at the battery compartment
    • Remove the five 4mm Phillips #1 screws from inside the battery compartment
    FixBot'a Sor
    Yorum Ekle
  9. OLPC XO-4 Touch Touchpad Controller Replacement: adım 9, 3 resimden 1. OLPC XO-4 Touch Touchpad Controller Replacement: adım 9, 3 resimden 2. OLPC XO-4 Touch Touchpad Controller Replacement: adım 9, 3 resimden 3.
    • Flip the laptop over, showing the top of the device.
    • Open the laptop and rotate the screen ninety degrees.
    • Tilt the screen so the lower right corner of the screen is closer to the lower case.
    FixBot'a Sor
    Yorum Ekle
  10. OLPC XO-4 Touch Touchpad Controller Replacement: adım 10, 3 resimden 1. OLPC XO-4 Touch Touchpad Controller Replacement: adım 10, 3 resimden 2. OLPC XO-4 Touch Touchpad Controller Replacement: adım 10, 3 resimden 3.
    • Push in and lift up on the keyboard edge of the white handle piece.
    • Pull the piece towards yourself to remove it from the laptop.
    FixBot'a Sor
    Yorum Ekle
  11. OLPC XO-4 Touch Touchpad Controller Replacement: adım 11, 1 resimden 1.
    • Remove the four 4mm Phillips #1 screws attaching the green trim to the body of the computer.
    FixBot'a Sor
    Yorum Ekle
  12. OLPC XO-4 Touch Touchpad Controller Replacement: adım 12, 2 resimden 1. OLPC XO-4 Touch Touchpad Controller Replacement: adım 12, 2 resimden 2.
    • Pry off the rear green trim piece.
    FixBot'a Sor
    Yorum Ekle
  13. OLPC XO-4 Touch Touchpad Controller Replacement: adım 13, 3 resimden 1. OLPC XO-4 Touch Touchpad Controller Replacement: adım 13, 3 resimden 2. OLPC XO-4 Touch Touchpad Controller Replacement: adım 13, 3 resimden 3.
    • Be careful not to pull the bottom portion of the laptop completely off, as there is a cable connecting it to the laptop.
    • Slide the green trim pieces away from the screen.
    • This should release the entire bottom portion of the laptop.
    FixBot'a Sor
    Yorum Ekle
  14. OLPC XO-4 Touch Touchpad Controller Replacement: adım 14, 3 resimden 1. OLPC XO-4 Touch Touchpad Controller Replacement: adım 14, 3 resimden 2. OLPC XO-4 Touch Touchpad Controller Replacement: adım 14, 3 resimden 3.
    • Unplug the cable from the mouse buttons controller to completely remove the lower frame from the device.
    FixBot'a Sor
    Yorum Ekle
  15. OLPC XO-4 Touch Touchpad Controller Replacement: adım 15, 2 resimden 1. OLPC XO-4 Touch Touchpad Controller Replacement: adım 15, 2 resimden 2.
    • Rotate the entire lower assembly up slightly, and pull it away from the screen to free it from the screen hinge.
    • There may be some adhesive holding the cable to the metal plate. Gently pull the cable off of the plate if it is stuck.
    FixBot'a Sor
    Yorum Ekle
  16. OLPC XO-4 Touch Touchpad Controller Replacement, Mouse Buttons Controller: adım 16, 3 resimden 1. OLPC XO-4 Touch Touchpad Controller Replacement, Mouse Buttons Controller: adım 16, 3 resimden 2. OLPC XO-4 Touch Touchpad Controller Replacement, Mouse Buttons Controller: adım 16, 3 resimden 3.
    • You should now be looking at the bottom of the lower case.
    • Remove the eight 4mm Phillips #1 screws attaching the green trim pieces to the lower frame.
    • Pry off the front and side trim pieces.
    FixBot'a Sor
    Yorum Ekle
  17. OLPC XO-4 Touch Touchpad Controller Replacement: adım 17, 1 resimden 1.
    • Remove the two 4mm Phillips #1 screws that attach the mouse buttons controller to the lower frame.
    FixBot'a Sor
    Yorum Ekle
  18. OLPC XO-4 Touch Touchpad Controller Replacement: adım 18, 3 resimden 1. OLPC XO-4 Touch Touchpad Controller Replacement: adım 18, 3 resimden 2. OLPC XO-4 Touch Touchpad Controller Replacement: adım 18, 3 resimden 3.
    • Disconnect the ribbon cable attached to the keyboard compartment.
    • Unplug the ribbon cable between the touchpad and the mouse buttons controller.
    • Remove the mouse buttons controller from the device.
    FixBot'a Sor
    Yorum Ekle
  19. OLPC XO-4 Touch Touchpad Controller Replacement, Touchpad Controller: adım 19, 1 resimden 1.
    • Remove the two 4mm Phillips screws that attach the metal plate to the touchpad assembly.
    • Be sure not to lose the silver magnet in the lower right corner of the touchpad assembly.
    FixBot'a Sor
    Yorum Ekle
  20. OLPC XO-4 Touch Touchpad Controller Replacement: adım 20, 3 resimden 1. OLPC XO-4 Touch Touchpad Controller Replacement: adım 20, 3 resimden 2. OLPC XO-4 Touch Touchpad Controller Replacement: adım 20, 3 resimden 3.
    • Remove the silver contact tape from the metal plate.
    • Lift the metal plate off of the touchpad assembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ekip
Cal Poly, Team 3-30, Amido Winter 2013 Cal Poly, Team 3-30, Amido Winter 2013 üyesi
CPSU-AMIDO-W13S3G30
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 28
Her zaman: 851
