Giriş
Use this guide to replace a broken touchpad.
Neye ihtiyacın var
Remove the five 4mm Phillips #1 screws from inside the battery compartment
Remove the eight 4mm Phillips #1 screws attaching the green trim pieces to the lower frame.
Pry off the front and side trim pieces.
Remove the two 4mm Phillips screws that attach the metal plate to the touchpad assembly.
Bir başkası bu kılavuzu tamamladı.
