Ana içeriğe geç
OPPO N1 Battery Replacement
Neye ihtiyacın var
  1. OPPO N1 Battery Replacement, Rear Case: adım 1, 1 resimden 1.
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
    FixBot'a Sor
    Yorum Ekle
  2. OPPO N1 Battery Replacement: adım 2, 2 resimden 1. OPPO N1 Battery Replacement: adım 2, 2 resimden 2.
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
    FixBot'a Sor
    Yorum Ekle
  3. OPPO N1 Battery Replacement, Battery: adım 3, 2 resimden 1. OPPO N1 Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
    FixBot'a Sor
    Yorum Ekle
  4. OPPO N1 Battery Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use the tweezers or your fingers to remove the sliver plates.
    FixBot'a Sor
    Yorum Ekle
  5. OPPO N1 Battery Replacement: adım 5, 1 resimden 1.
    • Remove the black plate with your fingers.
    FixBot'a Sor
    Yorum Ekle
  6. OPPO N1 Battery Replacement: adım 6, 3 resimden 1. OPPO N1 Battery Replacement: adım 6, 3 resimden 2. OPPO N1 Battery Replacement: adım 6, 3 resimden 3.
    • Use tweezers or your fingers to pull up the connector tabs.
    FixBot'a Sor
    Yorum Ekle
  7. OPPO N1 Battery Replacement: adım 7, 2 resimden 1. OPPO N1 Battery Replacement: adım 7, 2 resimden 2.
    • Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Joshua Stone
1.067 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 13-5, Staggers Fall 2014 USF Tampa, Team 13-5, Staggers Fall 2014 üyesi
USFT-STAGGERS-F14S13G5
3 Üyeler
20 adet Kılavuz yazıldı
4Kılavuz Yorumları
And where can I find that battery? What is the battery's id number? ebay doesn't show any. Just oppo n1 mini.
djkleinen - Yanıt Paylaş
Hi bigupbattery.com has them cheapest I've found the number is part no blp557
simon watling - Yanıt Paylaş
@simon watling
Omg, so big thanks, man! You just saved many euros for me!
How hard is it to pry the battery off the phone?
arkanista - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 48
Her zaman: 24,423
