Giriş
You will learn how to safely and efficiently remove the battery of the Oppo N1 smart phone.
Neye ihtiyacın var
Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
17 farklı kişi bu kılavuzu tamamladı.
4 Yorum
And where can I find that battery? What is the battery's id number? ebay doesn't show any. Just oppo n1 mini.
Hi bigupbattery.com has them cheapest I've found the number is part no blp557
