Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
The rear case should then come free.
Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
Use the tweezers or your fingers to remove the sliver plates.
Use tweezers or your fingers to pull up the connector tabs.
Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
17 farklı kişi bu kılavuzu tamamladı.
4 Yorum
And where can I find that battery? What is the battery's id number? ebay doesn't show any. Just oppo n1 mini.
Hi bigupbattery.com has them cheapest I've found the number is part no blp557
