Ana içeriğe geç
OPPO N1 Motherboard Replacement
Neye ihtiyacın var
    1. OPPO N1 Motherboard Replacement, Rear Case: adım 1, 1 resimden 1.
      • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
      FixBot'a Sor
      Yorum Ekle
    2. OPPO N1 Motherboard Replacement: adım 2, 2 resimden 1. OPPO N1 Motherboard Replacement: adım 2, 2 resimden 2.
      • In the photo we rotated the phone ninety degrees counterclockwise.
      • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
      • The rear case should then come free.
      FixBot'a Sor
      Yorum Ekle
    1. OPPO N1 Motherboard Replacement, Battery: adım 3, 2 resimden 1. OPPO N1 Motherboard Replacement, Battery: adım 3, 2 resimden 2.
      • Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
      FixBot'a Sor
      Yorum Ekle
    2. OPPO N1 Motherboard Replacement: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use the tweezers or your fingers to remove the sliver plates.
      FixBot'a Sor
      Yorum Ekle
    3. OPPO N1 Motherboard Replacement: adım 5, 1 resimden 1.
      • Remove the black plate with your fingers.
      FixBot'a Sor
      Yorum Ekle
    4. OPPO N1 Motherboard Replacement: adım 6, 3 resimden 1. OPPO N1 Motherboard Replacement: adım 6, 3 resimden 2. OPPO N1 Motherboard Replacement: adım 6, 3 resimden 3.
      • Use tweezers or your fingers to pull up the connector tabs.
      FixBot'a Sor
      Yorum Ekle
    5. OPPO N1 Motherboard Replacement: adım 7, 2 resimden 1. OPPO N1 Motherboard Replacement: adım 7, 2 resimden 2.
      • Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
      FixBot'a Sor
      Yorum Ekle
    1. OPPO N1 Motherboard Replacement, Motherboard: adım 8, 1 resimden 1.
      • Use tweezers or fingers to remove the three connector tabs.
      FixBot'a Sor
      Yorum Ekle
    2. OPPO N1 Motherboard Replacement: adım 9, 2 resimden 1. OPPO N1 Motherboard Replacement: adım 9, 2 resimden 2.
      • Use tweezers or your fingers to remove the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Joshua Stone
1.067 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 13-5, Staggers Fall 2014 USF Tampa, Team 13-5, Staggers Fall 2014 üyesi
USFT-STAGGERS-F14S13G5
3 Üyeler
20 adet Kılavuz yazıldı
3Kılavuz Yorumları
how much is the mother board for oppo f1
gillianrain28 - Yanıt Paylaş
Hi,I used a wrong car charger on my oppo n1 in the wrong port and since then my phone went off and never turns on.
Can I I sent the unit to you for repair?
danjuma kolo - Yanıt Paylaş
I used a round pin car charger at the earpiece port of my oppo n1…and the phone went off…tiok it for repair but still not working…can u be off assistance
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 5,829
