Ana içeriğe geç
OPPO N1 Screen Replacement
Neye ihtiyacın var
  1. OPPO N1 Screen Replacement, Rear Case: adım 1, 1 resimden 1.
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
    FixBot'a Sor
    Yorum Ekle
  2. OPPO N1 Screen Replacement: adım 2, 2 resimden 1. OPPO N1 Screen Replacement: adım 2, 2 resimden 2.
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
    FixBot'a Sor
    Yorum Ekle
  3. OPPO N1 Screen Replacement, Battery: adım 3, 2 resimden 1. OPPO N1 Screen Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
    FixBot'a Sor
    Yorum Ekle
  4. OPPO N1 Screen Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use the tweezers or your fingers to remove the sliver plates.
    FixBot'a Sor
    Yorum Ekle
  5. OPPO N1 Screen Replacement: adım 5, 1 resimden 1.
    • Remove the black plate with your fingers.
    FixBot'a Sor
    Yorum Ekle
  6. OPPO N1 Screen Replacement: adım 6, 3 resimden 1. OPPO N1 Screen Replacement: adım 6, 3 resimden 2. OPPO N1 Screen Replacement: adım 6, 3 resimden 3.
    • Use tweezers or your fingers to pull up the connector tabs.
    FixBot'a Sor
    Yorum Ekle
  7. OPPO N1 Screen Replacement: adım 7, 2 resimden 1. OPPO N1 Screen Replacement: adım 7, 2 resimden 2.
    • Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
    FixBot'a Sor
    Yorum Ekle
  8. OPPO N1 Screen Replacement, Motherboard: adım 8, 1 resimden 1.
    • Use tweezers or fingers to remove the three connector tabs.
    FixBot'a Sor
    Yorum Ekle
  9. OPPO N1 Screen Replacement: adım 9, 2 resimden 1. OPPO N1 Screen Replacement: adım 9, 2 resimden 2.
    • Use tweezers or your fingers to remove the motherboard.
    FixBot'a Sor
    Yorum Ekle
  10. OPPO N1 Screen Replacement, Headphone Jack and Speaker Cover: adım 10, 1 resimden 1.
    • Remove the two 4mm long screws using the ph0 Phillips head screw driver.
    • Remove the six 3mm long screws using the ph0 Phillips head screw driver.
    FixBot'a Sor
    Yorum Ekle
  11. OPPO N1 Screen Replacement: adım 11, 2 resimden 1. OPPO N1 Screen Replacement: adım 11, 2 resimden 2.
    • Use tweezers or your fingers to remove the plastic cover.
    FixBot'a Sor
    Yorum Ekle
  12. OPPO N1 Screen Replacement, Screen: adım 12, 1 resimden 1.
    • Use tweezers to disconnect the connector tab.
    FixBot'a Sor
    Yorum Ekle
  13. OPPO N1 Screen Replacement: adım 13, 1 resimden 1.
    • Use tweezers to peel the black strip from the sticky tape attached to the phone so that the black strip will slide through the phone once the screen is removed.
    • Be gentle removing the black strip at this stage. It can easily tear and it must be removed in order to remove the screen.
    FixBot'a Sor
    Yorum Ekle
  14. OPPO N1 Screen Replacement: adım 14, 3 resimden 1. OPPO N1 Screen Replacement: adım 14, 3 resimden 2. OPPO N1 Screen Replacement: adım 14, 3 resimden 3.
    • Insert the blue opening tool into the crevice between the screen and the main body of the phone. Gently slide the tool around the edge of the phone.
    FixBot'a Sor
    Yorum Ekle
  15. OPPO N1 Screen Replacement: adım 15, 2 resimden 1. OPPO N1 Screen Replacement: adım 15, 2 resimden 2.
    • Insert the blue opening tool in between the black screen and the white border and slide it around the edge of the black screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Joshua Stone
1.067 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 13-5, Staggers Fall 2014 USF Tampa, Team 13-5, Staggers Fall 2014 üyesi
USFT-STAGGERS-F14S13G5
3 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 15
Son 30 gün: 52
Her zaman: 5,963
