Giriş
After completing the prerequisite guides we will be showing you the step by step process of removing & or disconneting components of the screen.
Parçalar
Hiçbir parça belirtilmedi.
Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
Remove the two 4mm long screws using the ph0 Phillips head screw driver.
Remove the six 3mm long screws using the ph0 Phillips head screw driver.
10 farklı kişi bu kılavuzu tamamladı.
