Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
The rear case should then come free.
Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
Use the tweezers or your fingers to remove the sliver plates.
Use tweezers or your fingers to pull up the connector tabs.
Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
Use tweezers or fingers to remove the three connector tabs.
Use tweezers or your fingers to remove the motherboard.
Remove the two 4mm long screws using the ph0 Phillips head screw driver.
Remove the six 3mm long screws using the ph0 Phillips head screw driver.
Use tweezers or your fingers to remove the plastic cover.
Use tweezers to peel the black strip from the sticky tape attached to the phone so that the black strip will slide through the phone once the screen is removed.
Insert the blue opening tool into the crevice between the screen and the main body of the phone. Gently slide the tool around the edge of the phone.
Insert the blue opening tool in between the black screen and the white border and slide it around the edge of the black screen.
10 farklı kişi bu kılavuzu tamamladı.
