Ana içeriğe geç
Oculus Quest 2 Disassembly
Neye ihtiyacın var
  1. Oculus Quest 2 Disassembly, Unscrew the rear cover: adım 1, 1 resimden 1.
    • Start by removing the six T2 screws that hold the inner lining of the headset to the front.
    FixBot'a Sor
    Yorum Ekle
  2. Oculus Quest 2 Disassembly, Remove the rear cover: adım 2, 2 resimden 1. Oculus Quest 2 Disassembly, Remove the rear cover: adım 2, 2 resimden 2.
    • One side at a time, insert a pick next to the nosepiece, slide it to the edge and pry.
    • When both sides are loose, carefully lift the cover out, and fold it so that the nose piece is on the outer perimeter of the device, as shown in the second image.
    • The proximity sensor is still connected via a flex cable, so be careful to not rip or crease the cable.
    • Lift the small black clip on the ZIF connecter up, and pull the flex cable out.
    • The cable is lightly adhered to the headset so be careful when removing it.
    • During reassembly, make sure to position the cable correctly. Latching the small black clip back on shouldn't require much force. If you don't connect the cable correctly, the headset's screen may stay black and the device will turn off after a few seconds.
    FixBot'a Sor
    Yorum Ekle
  3. Oculus Quest 2 Disassembly, Detach ZIF Connector: adım 3, 3 resimden 1. Oculus Quest 2 Disassembly, Detach ZIF Connector: adım 3, 3 resimden 2. Oculus Quest 2 Disassembly, Detach ZIF Connector: adım 3, 3 resimden 3.
    • The ribbon cable is lightly attached to the headset with adhesive and the cable is connected with a ZIF connector. Consult Step 1 of the Recognizing & Disconnecting Cable Connectors guide (RDCC guide) for ZIF connector info.
    • Use the tip of a spudger to flip up the locking flap to release the cable. See pictures 2 and 3 to understand how the flap operates.
    FixBot'a Sor
    Yorum Ekle
  4. Oculus Quest 2 Disassembly, Unscrew the front cover: adım 4, 1 resimden 1.
    • Remove the three P000 screws.
    • Remove the two P000 screws
    • The two orange screws near the top are very deep, a longer head screwdriver may be required
    FixBot'a Sor
    Yorum Ekle
  5. Oculus Quest 2 Disassembly, Remove the front cover: adım 5, 2 resimden 1. Oculus Quest 2 Disassembly, Remove the front cover: adım 5, 2 resimden 2.
    • Insert a pick and pry at these four spots to release the clips.
    • Lift the front cover away from the headset.
    FixBot'a Sor
    Yorum Ekle
  6. Oculus Quest 2 Disassembly, Remove the battery bracket: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Unplug the side WiFi antenna. See step 5 of the RDCC guide. To disconnect the cable, slide a thin, ESD-safe pry tool or tweezers under the metal neck of the connector and lift straight up from the board.
    • Remove the 4.4 mm P000 screw
    • Remove the two 2.3 mm P000 screws
    FixBot'a Sor
    Yorum Ekle
  7. Oculus Quest 2 Disassembly, Unplug the battery: adım 7, 2 resimden 1. Oculus Quest 2 Disassembly, Unplug the battery: adım 7, 2 resimden 2.
    • Unplug the battery. See Step 4 of the RDCC Guide. Use the spudger to pry the connector straight up.
    • Remember to put part of the battery ribbon cable under the logic board when reassembling.
    FixBot'a Sor
    Yorum Ekle
  8. Oculus Quest 2 Disassembly, Remove the Bluetooth antenna: adım 8, 3 resimden 1. Oculus Quest 2 Disassembly, Remove the Bluetooth antenna: adım 8, 3 resimden 2. Oculus Quest 2 Disassembly, Remove the Bluetooth antenna: adım 8, 3 resimden 3.
    • Remove two P000, 4.8 mm long screws.
    • Remove four P000, 4.8 mm long screws.
    • Remove two P000, 10.7 mm long screws.
    • The arrow points to the Bluetooth antenna. To disconnect see step 5 of the Guide. Go to picture 2. To disconnect the cable, slide a thin, ESD-safe pry tool or tweezers under the metal neck of the connector and lift straight up from the board.
    • Picture 3. Remove the antenna from the headset.
    FixBot'a Sor
    Yorum Ekle
  9. Oculus Quest 2 Disassembly, Remove the cooling fan: adım 9, 3 resimden 1. Oculus Quest 2 Disassembly, Remove the cooling fan: adım 9, 3 resimden 2. Oculus Quest 2 Disassembly, Remove the cooling fan: adım 9, 3 resimden 3.
    • Unplug the fan.
    • Remove the T2 screw
    • Remove the P000 screw
    • Lift the front LED away from the headset.
    • Lift the fan away from the headset.
    FixBot'a Sor
    Yorum Ekle
  10. Oculus Quest 2 Disassembly, Remove the heatsink: adım 10, 1 resimden 1.
    • Remove the four P000 screws
    • Remove the heatsink.
    FixBot'a Sor
    Yorum Ekle
  11. Oculus Quest 2 Disassembly, Disconnect ZIF, WiFi and USB cables: adım 11, 3 resimden 1. Oculus Quest 2 Disassembly, Disconnect ZIF, WiFi and USB cables: adım 11, 3 resimden 2. Oculus Quest 2 Disassembly, Disconnect ZIF, WiFi and USB cables: adım 11, 3 resimden 3.
    • There are 2 ZIF connectors near the top of the mainboard. The ZIF flap on the right has been opened. The ZIF flap is opened by pushing down in the direction of the orange arrow.
    • Unlatch both ZIF connectors and disconnect the cables. These cables lead to the front LED and IPD sensor, and proximity sensor.
    • Unplug the side WiFi antenna connector. See step 5 of the RDCC guide. To disconnect the cable, slide a thin, ESD-safe pry tool or tweezers under the metal neck of the connector and lift straight up from the board.
    • Unplug the cable leading to the USB Type-C port and headphone jack. See Step 4 of the RDCC Guide. Use the spudger to pry the press connector straight up.
    FixBot'a Sor
    Yorum Ekle
  12. Oculus Quest 2 Disassembly, Disconnect Speakers from Main Board: adım 12, 3 resimden 1. Oculus Quest 2 Disassembly, Disconnect Speakers from Main Board: adım 12, 3 resimden 2. Oculus Quest 2 Disassembly, Disconnect Speakers from Main Board: adım 12, 3 resimden 3.
    • Two sets of speaker cables are connected to the main board.
    • Grab the wires and pull out to disconnect the speaker cables.
    FixBot'a Sor
    Yorum Ekle
  13. Oculus Quest 2 Disassembly, Disconnect Top Cameras: adım 13, 3 resimden 1. Oculus Quest 2 Disassembly, Disconnect Top Cameras: adım 13, 3 resimden 2. Oculus Quest 2 Disassembly, Disconnect Top Cameras: adım 13, 3 resimden 3.
    • Disconnect the ZIF connectors for the top cameras
    • The ZIF connector is shown in the second picture. A spudger should be used to push up the locking flap as shown by the red arrow.
    • When the flap is open the ribbon cable may be pulled from the connector.
    • Remember to do both camera ZIF connectors.
    • When reassembling, note that the camera covers are unique to each side. The holes in the covers should be pointed up and in the proper location.
    FixBot'a Sor
    Yorum Ekle
  14. Oculus Quest 2 Disassembly, Disconnect Bottom Cameras & Power: adım 14, 2 resimden 1. Oculus Quest 2 Disassembly, Disconnect Bottom Cameras & Power: adım 14, 2 resimden 2.
    • Open the flaps on the three ZIF connectors and detach the ribbon cables.
    FixBot'a Sor
    Yorum Ekle
  15. Oculus Quest 2 Disassembly, Disconnect the Screen Cable: adım 15, 2 resimden 1. Oculus Quest 2 Disassembly, Disconnect the Screen Cable: adım 15, 2 resimden 2.
    • The screen cable is attached with a press connector.
    • Use the spudger to pry the press connector straight up. See Step 4 of the RDCC Guide.
    FixBot'a Sor
    Yorum Ekle
  16. Oculus Quest 2 Disassembly, Remove the mainboard: adım 16, 1 resimden 1.
    • Remove the following screws:
    • One 3.5mm hex screw
    • Four P000 screws
    • These screws are non-magnetic.
    • Remove the mainboard.
    FixBot'a Sor
    Yorum Ekle
  17. Oculus Quest 2 Disassembly, Mainboard: adım 17, 2 resimden 1. Oculus Quest 2 Disassembly, Mainboard: adım 17, 2 resimden 2.
    • Close up on the mainboard.
    FixBot'a Sor
    Yorum Ekle
  18. Oculus Quest 2 Disassembly, Disconnect the Power to the Midframe: adım 18, 3 resimden 1. Oculus Quest 2 Disassembly, Disconnect the Power to the Midframe: adım 18, 3 resimden 2. Oculus Quest 2 Disassembly, Disconnect the Power to the Midframe: adım 18, 3 resimden 3.
    • Unroute the side WiFi antenna.
    • The battery power comes to the midframe through this cable. The cable has a metal pad on the bottom and is attached to the midframe with glue. Separate the metal plate on the bottom of the connector from the midframe.
    FixBot'a Sor
    Yorum Ekle
  19. Oculus Quest 2 Disassembly, Remove the Midframe: adım 19, 1 resimden 1.
    • The midframe is removed giving access to the battery.
    FixBot'a Sor
    Yorum Ekle
  20. Oculus Quest 2 Disassembly, Battery Removal: adım 20, 2 resimden 1. Oculus Quest 2 Disassembly, Battery Removal: adım 20, 2 resimden 2.
    • Remove the two P000 screws, which hold the battery to the front of the case.
    • Remove the four P000, which hold the battery to the back of the case.
    FixBot'a Sor
    Yorum Ekle
  21. Oculus Quest 2 Disassembly, Battery Case: adım 21, 2 resimden 1. Oculus Quest 2 Disassembly, Battery Case: adım 21, 2 resimden 2.
    • Remove the three T2 screws, which hold the cover on the battery case.
    • After the cover is removed.
    • The Quest 2 has a battery life of 2.5 hours, drawing an average of 5.6W.
    FixBot'a Sor
    Yorum Ekle
  22. Oculus Quest 2 Disassembly, Remove the USB/Speakers/Arms: adım 22, 3 resimden 1. Oculus Quest 2 Disassembly, Remove the USB/Speakers/Arms: adım 22, 3 resimden 2. Oculus Quest 2 Disassembly, Remove the USB/Speakers/Arms: adım 22, 3 resimden 3.
    • Release the speaker wire from the speaker retainer.
    • Remove the seven P000 screws from the speaker retainer and USB port.
    • Use the spudger to free the speaker retainer.
    • Remove the USB charge port and the speaker retainer.
    FixBot'a Sor
    Yorum Ekle
  23. Oculus Quest 2 Disassembly, Removing the Springs: adım 23, 2 resimden 1. Oculus Quest 2 Disassembly, Removing the Springs: adım 23, 2 resimden 2.
    • Use a small screwdriver to tip up the tabs on the springs.
    • Remove the springs using needle nose pliers.
    FixBot'a Sor
    Yorum Ekle
  24. Oculus Quest 2 Disassembly, Arm Speaker Attachment Method: adım 24, 3 resimden 1. Oculus Quest 2 Disassembly, Arm Speaker Attachment Method: adım 24, 3 resimden 2. Oculus Quest 2 Disassembly, Arm Speaker Attachment Method: adım 24, 3 resimden 3.
    • The arm and speaker are passed through the headset and locked in place with the rubber retaining ring.
    • Tabs in the rubber retaining ring pass through the slots in the arm. These are the slots that previously held the springs. the ring is turned to lock or unlock the arm.
    FixBot'a Sor
    Yorum Ekle
  25. Oculus Quest 2 Disassembly, Arm / Speaker Removal: adım 25, 3 resimden 1. Oculus Quest 2 Disassembly, Arm / Speaker Removal: adım 25, 3 resimden 2. Oculus Quest 2 Disassembly, Arm / Speaker Removal: adım 25, 3 resimden 3.
    • How you grasp the retaining ring depends on which arm you are working on.
    • When you are working on the arm located near the on/off button, you must put your hand through the part of the headset that is normally towards your face to grasp the retaining ring. You then push the arm down in the direction shown in the second picture.
    • When working on the arm located near the USB port you must put your hand through the front of the headset to grasp the retaining ring. You then push the arm down as shown in the third picture.
    FixBot'a Sor
    Yorum Ekle
  26. Oculus Quest 2 Disassembly, Lens assembly: adım 26, 3 resimden 1. Oculus Quest 2 Disassembly, Lens assembly: adım 26, 3 resimden 2. Oculus Quest 2 Disassembly, Lens assembly: adım 26, 3 resimden 3.
    • Small metal tabs hold the guide rails that the lenses slide on. Removing the rails reveals the display.
    • There is a protective sheet of plastic over the screen. Be careful of dust and scratches.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
144 farklı kişi bu kılavuzu tamamladı.
sctanf
2.576 İtibar
1 Kılavuz yazıldı
90Kılavuz Yorumları
Thank you so much to me for making this guide. Helped me a lot!
It is worth emphasizing that this device has 2! WIFI antennas.
Anyone who wants to disconnect WIFI from their device must disconnect both.
Their connection to the motherboard, is right next to each other, but the right connection is immediately revealed while the left connection next to it is hidden under the black cover and requires a number of additional disassembly steps.
Alternatively, anyone who wants to disconnect WIFI from their device can disconnect the wires in the area where they connect to the antenna stickers on the right and left sides of the eyepieces of the glasses, thus saving all the disassembly of the front cover.
שמחה גרשון בורר - Yanıt Paylaş
Thanks!! this really helped me, I have already customized mine with an official custom filter, but this will add an additional layer of Kashrus.
Leib Felberbaum - Yanıt Paylaş
If you just need to replace a camera… it’s 14 screws. You need a T2 and a PH0 (not a P0…) Pretty easy once you get the front cover off and not covered here. It’s pretty easy to see what you do once you get in there though. Good luck!
Chris Madson - Yanıt Paylaş
PH0 and P0 are the same :)
Lylo - Yanıt Paylaş
Bravo pour ces informations. Un grand merci
Guidemann Christophe - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 64
Son 7 gün: 525
Son 30 gün: 2,389
Her zaman: 320,660
