Ana içeriğe geç
Oculus Rift CV1 Facial Interface Replacement
Neye ihtiyacın var
  1. Oculus Rift CV1 Facial Interface Replacement, Facial Interface: adım 1, 1 resimden 1.
    • Pull firmly from the top of the headset facial interface to remove the foam frame.
  2. Oculus Rift CV1 Facial Interface Replacement: adım 2, 1 resimden 1.
    • Remove the six T3 4mm screws from the top and bottom edges of the case.
  3. Oculus Rift CV1 Facial Interface Replacement: adım 3, 1 resimden 1.
    • Insert the spudger underneath the edge of the lens on the left or right side.
    • Slide the spudger upwards and around the edge of the frame to undo the tabs underneath.
    • Repeat for the other side of the frame.
  4. Oculus Rift CV1 Facial Interface Replacement: adım 4, 3 resimden 1. Oculus Rift CV1 Facial Interface Replacement: adım 4, 3 resimden 2. Oculus Rift CV1 Facial Interface Replacement: adım 4, 3 resimden 3.
    • Lift up the frame to see a tab hidden underneath the lycra mesh along the edge of the lens.
    • Pull up on the tab with the spudger.
    • Repeat for the corresponding tab on the other lens.
  5. Oculus Rift CV1 Facial Interface Replacement: adım 5, 1 resimden 1.
    • Lift up on the plastic frame around the lens.
    • Slide a finger around the inside edge, pulling outward from the center of the lens to release the other tabs.
    • Repeat for the frame on the other lens.
  6. Oculus Rift CV1 Facial Interface Replacement: adım 6, 1 resimden 1.
    • Pull up along the outer frame.
    • Remove the facial interface.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kyle Anderson
226 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G4, White Winter 2019 Cal Poly, Team S18-G4, White Winter 2019 üyesi
CPSU-WHITE-W19S18G4
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 4,776
