Giriş
If you find that there is no sound from the headphones and cannot find a solution of how to fix the headphones, perhaps it is time to replace. This guide will show you how to detach the headphones from the head strap. You will need a 4mm Flathead screwdriver for this replacement.
Neye ihtiyacın var
Loosen the 4mm Flathead screw from the head strap.
Repeat for the headphone on the other side.
3 farklı kişi bu kılavuzu tamamladı.
4 Yorum
can you do a tear down of these headphones?
This is an assembly. Could u please fix the issue of the screw getting loose on the actual ear piece, please. Which goes into having to fix something that is a real headache for most of us. please.
