Ana içeriğe geç
Oculus Rift CV1 Remote Button Replacement
Neye ihtiyacın var
  1. Oculus Rift CV1 Remote Button Replacement, Battery: adım 1, 3 resimden 1. Oculus Rift CV1 Remote Button Replacement, Battery: adım 1, 3 resimden 2. Oculus Rift CV1 Remote Button Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the back panel by firmly sliding it towards the strap.
    FixBot'a Sor
    Yorum Ekle
  2. Oculus Rift CV1 Remote Button Replacement: adım 2, 3 resimden 1. Oculus Rift CV1 Remote Button Replacement: adım 2, 3 resimden 2. Oculus Rift CV1 Remote Button Replacement: adım 2, 3 resimden 3.
    • Push down on the tab under the battery.
    • Firmly slide the battery away from you. The battery should unlatch from its previous position.
    • Once the battery is removed, release the tab.
    FixBot'a Sor
    Yorum Ekle
  3. Oculus Rift CV1 Remote Button Replacement, Remote Button: adım 3, 1 resimden 1.
    • Remove the four 4mm Phillips #000 screws from the back of the remote.
    FixBot'a Sor
    Yorum Ekle
  4. Oculus Rift CV1 Remote Button Replacement: adım 4, 1 resimden 1.
    • Gently lift the wrist strap to split the back panel into two.
    FixBot'a Sor
    Yorum Ekle
  5. Oculus Rift CV1 Remote Button Replacement: adım 5, 2 resimden 1. Oculus Rift CV1 Remote Button Replacement: adım 5, 2 resimden 2.
    • Gently peel off the top of the control board.
    • Be gentle, if the buttons fall off, try to keep them in the orientation that they were in.
    • If the large black button falls off, place it back into the shell by orienting the tabs on the button to match the holes on the shell.
    FixBot'a Sor
    Yorum Ekle
  6. Oculus Rift CV1 Remote Button Replacement: adım 6, 1 resimden 1.
    • Pull the old buttons off and replace them with the new ones.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Christian Perry
223 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G4, White Winter 2019 Cal Poly, Team S18-G4, White Winter 2019 üyesi
CPSU-WHITE-W19S18G4
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 42
Her zaman: 1,302
