Giriş
This guide will teach you how to disassemble the control box of the Oculus Rift DK1.
  1. Use a plastic opening tool to carefully pry off the four rubber feet from the control box. You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet. You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
    • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
    • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
  2. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box. You can now remove the bottom lid of the control box. It should come apart easily. You can now remove the bottom lid of the control box. It should come apart easily.
    • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
    • You can now remove the bottom lid of the control box. It should come apart easily.
Sonuç
Audrey Chan
201 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 70-5, Forte Winter 2015 Cal Poly, Team 70-5, Forte Winter 2015 üyesi
CPSU-FORTE-W15S70G5
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 3
Son 30 Gün: 5
Her zaman: 307
