Ana içeriğe geç
Oculus Rift Development Kit 2 Display Screen Replacement
Neye ihtiyacın var
  1. Oculus Rift Development Kit 2 Display Screen Replacement, Eye Relief Adjustment Screw: adım 1, 3 resimden 1. Oculus Rift Development Kit 2 Display Screen Replacement, Eye Relief Adjustment Screw: adım 1, 3 resimden 2. Oculus Rift Development Kit 2 Display Screen Replacement, Eye Relief Adjustment Screw: adım 1, 3 resimden 3.
    • Remove front cover plate.
    • Unplug the USB and HDMI cables from the Oculus Rift DK2.
    FixBot'a Sor
    Yorum Ekle
  2. Oculus Rift Development Kit 2 Display Screen Replacement: adım 2, 3 resimden 1. Oculus Rift Development Kit 2 Display Screen Replacement: adım 2, 3 resimden 2. Oculus Rift Development Kit 2 Display Screen Replacement: adım 2, 3 resimden 3.
    • Remove the four 3/8" Phillips #0 screws from the inner portion of the headset.
    FixBot'a Sor
    Yorum Ekle
  3. Oculus Rift Development Kit 2 Display Screen Replacement: adım 3, 2 resimden 1. Oculus Rift Development Kit 2 Display Screen Replacement: adım 3, 2 resimden 2.
    • With the screws removed, gently pull the headband frame apart from the headset.
    FixBot'a Sor
    Yorum Ekle
  4. Oculus Rift Development Kit 2 Display Screen Replacement, Remove Lens: adım 4, 2 resimden 1. Oculus Rift Development Kit 2 Display Screen Replacement, Remove Lens: adım 4, 2 resimden 2.
    • With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
    FixBot'a Sor
    Yorum Ekle
  5. Oculus Rift Development Kit 2 Display Screen Replacement, Headset Motherboard: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
    FixBot'a Sor
    Yorum Ekle
  6. Oculus Rift Development Kit 2 Display Screen Replacement: adım 6, 1 resimden 1.
    • Remove the four 3/8" screws attaching the eyewear enclosure to the front casing.
    • Read the next step before removing the faceplate!
    FixBot'a Sor
    Yorum Ekle
  7. Oculus Rift Development Kit 2 Display Screen Replacement: adım 7, 2 resimden 1. Oculus Rift Development Kit 2 Display Screen Replacement: adım 7, 2 resimden 2.
    • Carefully separate the faceplate and the cover. Gently rest the cover plate on top of the faceplate as shown in the pictures.
    • Do not use excessive force when separating these two pieces. There is a delicate ribbon cable connected to each.
    FixBot'a Sor
    Yorum Ekle
  8. Oculus Rift Development Kit 2 Display Screen Replacement: adım 8, 2 resimden 1. Oculus Rift Development Kit 2 Display Screen Replacement: adım 8, 2 resimden 2.
    • Gently pull out the small side tabs on the ribbon cable connector as shown to release the cable.
    • Push the tabs away from you, with the headset oriented as pictured. Carefully slide the ribbon cable out.
    • The headset should now be two separate pieces.
    FixBot'a Sor
    Yorum Ekle
  9. Oculus Rift Development Kit 2 Display Screen Replacement: adım 9, 3 resimden 1. Oculus Rift Development Kit 2 Display Screen Replacement: adım 9, 3 resimden 2. Oculus Rift Development Kit 2 Display Screen Replacement: adım 9, 3 resimden 3.
    • Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out.
    FixBot'a Sor
    Yorum Ekle
  10. Oculus Rift Development Kit 2 Display Screen Replacement: adım 10, 1 resimden 1.
    • Lift the tape and gently pry up the video data ribbon cable using the plastic opening tool as shown.
    FixBot'a Sor
    Yorum Ekle
  11. Oculus Rift Development Kit 2 Display Screen Replacement: adım 11, 3 resimden 1. Oculus Rift Development Kit 2 Display Screen Replacement: adım 11, 3 resimden 2. Oculus Rift Development Kit 2 Display Screen Replacement: adım 11, 3 resimden 3.
    • Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free.
    FixBot'a Sor
    Yorum Ekle
  12. Oculus Rift Development Kit 2 Display Screen Replacement, Display Screen: adım 12, 3 resimden 1. Oculus Rift Development Kit 2 Display Screen Replacement, Display Screen: adım 12, 3 resimden 2. Oculus Rift Development Kit 2 Display Screen Replacement, Display Screen: adım 12, 3 resimden 3.
    • Remove the six 1/4" Phillips #1 screws as shown. There should be two on each short side, and one on each long side.
    • Gently lift the plastic screen holder and display screen away from the remaining piece of the faceplate.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Adam
661 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-5, Maness Winter 2015 Cal Poly, Team 18-5, Maness Winter 2015 üyesi
CPSU-MANESS-W15S18G5
4 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
It's possible to use the Samsung Galaxy Note 4 screen?
Lauro Adriano Freitas - Yanıt Paylaş
moldovancasyan19 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 38
Her zaman: 3,273
