Ana içeriğe geç
Oculus Rift Development Kit 2 Headset Motherboard Replacement
Neye ihtiyacın var
  1. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: adım 1, 3 resimden 1. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: adım 1, 3 resimden 2. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: adım 1, 3 resimden 3.
    • Remove front cover plate.
    • Unplug the USB and HDMI cables from the Oculus Rift DK2.
  2. Oculus Rift Development Kit 2 Headset Motherboard Replacement: adım 2, 3 resimden 1. Oculus Rift Development Kit 2 Headset Motherboard Replacement: adım 2, 3 resimden 2. Oculus Rift Development Kit 2 Headset Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the four 3/8" Phillips #0 screws from the inner portion of the headset.
  3. Oculus Rift Development Kit 2 Headset Motherboard Replacement: adım 3, 2 resimden 1. Oculus Rift Development Kit 2 Headset Motherboard Replacement: adım 3, 2 resimden 2.
    • With the screws removed, gently pull the headband frame apart from the headset.
  4. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Remove Lens: adım 4, 2 resimden 1. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Remove Lens: adım 4, 2 resimden 2.
    • With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
  5. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Headset Motherboard: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
  6. Oculus Rift Development Kit 2 Headset Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the four 3/8" screws attaching the eyewear enclosure to the front casing.
    • Read the next step before removing the faceplate!
  7. Oculus Rift Development Kit 2 Headset Motherboard Replacement: adım 7, 2 resimden 1. Oculus Rift Development Kit 2 Headset Motherboard Replacement: adım 7, 2 resimden 2.
    • Carefully separate the faceplate and the cover. Gently rest the cover plate on top of the faceplate as shown in the pictures.
    • Do not use excessive force when separating these two pieces. There is a delicate ribbon cable connected to each.
  8. Oculus Rift Development Kit 2 Headset Motherboard Replacement: adım 8, 2 resimden 1. Oculus Rift Development Kit 2 Headset Motherboard Replacement: adım 8, 2 resimden 2.
    • Gently pull out the small side tabs on the ribbon cable connector as shown to release the cable.
    • Push the tabs away from you, with the headset oriented as pictured. Carefully slide the ribbon cable out.
    • The headset should now be two separate pieces.
  9. Oculus Rift Development Kit 2 Headset Motherboard Replacement: adım 9, 3 resimden 1. Oculus Rift Development Kit 2 Headset Motherboard Replacement: adım 9, 3 resimden 2. Oculus Rift Development Kit 2 Headset Motherboard Replacement: adım 9, 3 resimden 3.
    • Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out.
  10. Oculus Rift Development Kit 2 Headset Motherboard Replacement: adım 10, 1 resimden 1.
    • Lift the tape and gently pry up the video data ribbon cable using the plastic opening tool as shown.
  11. Oculus Rift Development Kit 2 Headset Motherboard Replacement: adım 11, 3 resimden 1. Oculus Rift Development Kit 2 Headset Motherboard Replacement: adım 11, 3 resimden 2. Oculus Rift Development Kit 2 Headset Motherboard Replacement: adım 11, 3 resimden 3.
    • Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Adam
661 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-5, Maness Winter 2015 Cal Poly, Team 18-5, Maness Winter 2015 üyesi
CPSU-MANESS-W15S18G5
4 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
hi.
you know where possible buy the new motherboard?
Szatmari Attila - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 2,649
