Ana içeriğe geç
Oculus Rift Tracker V2 Board Replacement
Neye ihtiyacın var
  1. Oculus Rift Tracker V2 Board Replacement, Lens: adım 1, 2 resimden 1. Oculus Rift Tracker V2 Board Replacement, Lens: adım 1, 2 resimden 2.
    • To remove the lenses, turn the right lens clockwise a quarter turn and the left lens counter-clockwise a quarter turn.
    FixBot'a Sor
    Yorum Ekle
  2. Oculus Rift Tracker V2 Board Replacement, Display: adım 2, 2 resimden 1. Oculus Rift Tracker V2 Board Replacement, Display: adım 2, 2 resimden 2.
    • Use a Phillips #01 screwdriver to unscrew the four 9 mm Phillips #01 screws. (Two screws are shown in the picture, and two more screws are on the left side across from the right screws.)
    FixBot'a Sor
    Yorum Ekle
  3. Oculus Rift Tracker V2 Board Replacement: adım 3, 3 resimden 1. Oculus Rift Tracker V2 Board Replacement: adım 3, 3 resimden 2. Oculus Rift Tracker V2 Board Replacement: adım 3, 3 resimden 3.
    • Carefully lift the headstrap from the display. The two parts should separate easily enough with some force.
    • Once the headstrap assembly and display box are separated, the headstrap assembly can be set aside. You will be working with the display box for the rest of this guide!
    FixBot'a Sor
    Yorum Ekle
  4. Oculus Rift Tracker V2 Board Replacement: adım 4, 2 resimden 1. Oculus Rift Tracker V2 Board Replacement: adım 4, 2 resimden 2.
    • Using the plastic opening tool, pry open the display box to reveal the LCD (Liquid Crystal Display) screen. Run the plastic opening tool around all four edges. Prying open the box may take a good amount of force.
    FixBot'a Sor
    Yorum Ekle
  5. Oculus Rift Tracker V2 Board Replacement: adım 5, 3 resimden 1. Oculus Rift Tracker V2 Board Replacement: adım 5, 3 resimden 2. Oculus Rift Tracker V2 Board Replacement: adım 5, 3 resimden 3.
    • Run the plastic opening tool along the bottom edge under the LCD screen to separate the adhesive holding the LCD to the display box.
    • Lift the screen up to reveal the wires and circuit board.
    • Ensure that all wires are in the right place upon reassembly.
    FixBot'a Sor
    Yorum Ekle
  6. Oculus Rift Tracker V2 Board Replacement: adım 6, 2 resimden 1. Oculus Rift Tracker V2 Board Replacement: adım 6, 2 resimden 2.
    • Remove the wires from the circuit board on the LCD display using your fingernail or a plastic opening tool. This may take some pushing and pulling of the plastic piece.
    • Don't pull on the wires! Be sure to only pry the plastic part.
    • You can now completely separate the LCD screen from the rest of the device!
    FixBot'a Sor
    Yorum Ekle
  7. Oculus Rift Tracker V2 Board Replacement, Oculus Tracker V2 Board: adım 7, 1 resimden 1.
    • Remove wires from the Tracker V2 Board using your fingernail or a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  8. Oculus Rift Tracker V2 Board Replacement: adım 8, 3 resimden 1. Oculus Rift Tracker V2 Board Replacement: adım 8, 3 resimden 2. Oculus Rift Tracker V2 Board Replacement: adım 8, 3 resimden 3.
    • On the front cover of the Oculus Headset, locate the Tracker V2 Board.
    • Using the Plastic Opening Tool, pry the board from the adhesive. You will need to lift from both sides of the board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jake Finelt
146 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 70-5, Forte Winter 2015 Cal Poly, Team 70-5, Forte Winter 2015 üyesi
CPSU-FORTE-W15S70G5
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 43
Her zaman: 1,536
