Ana içeriğe geç
Oculus Touch Controllers (2nd generation) Battery Replacement
Neye ihtiyacın var
  1. Oculus Touch Controllers (2nd generation) Battery Replacement, Opening: adım 1, 1 resimden 1.
    • Slide down the cover on the left or right side of your chosen controller.
  2. Oculus Touch Controllers (2nd generation) Battery Replacement, Taking out the battery: adım 2, 3 resimden 1. Oculus Touch Controllers (2nd generation) Battery Replacement, Taking out the battery: adım 2, 3 resimden 2. Oculus Touch Controllers (2nd generation) Battery Replacement, Taking out the battery: adım 2, 3 resimden 3.
    • After opening, push forward the battery and lift it up while holding the ring on the controller with your other hand.
    • You can also use the top of the cover to push and lift the battery if you don't have an opening tool.
    • Recycle batteries properly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Artem Ivat
3.549 İtibar
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 35
Her zaman: 1,970
