Ana içeriğe geç
Office Chair Caster Wheels Replacement
Neye ihtiyacın var
  1. Office Chair Caster Wheels Replacement, Caster Wheels: adım 1, 3 resimden 1. Office Chair Caster Wheels Replacement, Caster Wheels: adım 1, 3 resimden 2. Office Chair Caster Wheels Replacement, Caster Wheels: adım 1, 3 resimden 3.
    • Turn the chair over to the side to access the caster wheels.
  2. Office Chair Caster Wheels Replacement: adım 2, 3 resimden 1. Office Chair Caster Wheels Replacement: adım 2, 3 resimden 2. Office Chair Caster Wheels Replacement: adım 2, 3 resimden 3.
    • Remove the caster wheels from the socket using any flat edge such as a metal spudger.
    • Be careful not to injure yourself while handling sharp objects.
  3. Office Chair Caster Wheels Replacement: adım 3, 3 resimden 1. Office Chair Caster Wheels Replacement: adım 3, 3 resimden 2. Office Chair Caster Wheels Replacement: adım 3, 3 resimden 3.
    • Wipe off the caster wheel bracket.
    • Optional: If you are having trouble spinning the wheels, apply a lubricant such as WD40.
  4. Office Chair Caster Wheels Replacement: adım 4, 3 resimden 1. Office Chair Caster Wheels Replacement: adım 4, 3 resimden 2. Office Chair Caster Wheels Replacement: adım 4, 3 resimden 3.
    • Get a firm grip on the caster wheels and put enough pressure to reinsert the caster back inside the socket.
    • Optional: If you are struggling to reinsert the caster, then try using a mallet or hammer to lock the wheels in place.
  5. Office Chair Caster Wheels Replacement: adım 5, 3 resimden 1. Office Chair Caster Wheels Replacement: adım 5, 3 resimden 2. Office Chair Caster Wheels Replacement: adım 5, 3 resimden 3.
    • Check to ensure that the wheels are secure.
    • We recommend lifting the chair or tilting it on each side to check for any loose wheels that could fall out.
  6. Office Chair Caster Wheels Replacement: adım 6, 3 resimden 1. Office Chair Caster Wheels Replacement: adım 6, 3 resimden 2. Office Chair Caster Wheels Replacement: adım 6, 3 resimden 3.
    • Have a seat and test the movement functionality.
    • Ask yourself if the chair is moving properly and are the wheels secure.
    • If the answer is yes, then congratulations! Your repair was successful! If not, try some of the optional points covered in the previous steps.
Bitiş Çizgisi
Ivan
133 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 90
Her zaman: 376
