Ana içeriğe geç
Ohmeda Engström Compressor Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Ohmeda Engström Compressor Replacement, Compressor: adım 1, 1 resimden 1.
    • Ensure the device is powered off and unplugged
    • Disconnect any wires or components that are plugged in prior to repair
  2. Ohmeda Engström Compressor Replacement: adım 2, 1 resimden 1.
    • Tap the back end of a flat head screwdriver with a hammer to wedge the side trim pieces away from the machine.
  3. Ohmeda Engström Compressor Replacement: adım 3, 1 resimden 1.
    • Use the flat head screwdriver to pry off and remove the side panels
    • When prying off the panels, do so carefully so that you do not to scratch or damage them
    • When reassembling the side panels, make sure that the connectors snap back into place.
    • Remove the mounting hardware from the compressor on the cart
  4. Ohmeda Engström Compressor Replacement: adım 4, 1 resimden 1.
    • Screw in the service tool to assist in lifting the compressor and sliding out of the cart
Sonuç
Kobe Hayashi
269 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G6, Paton Spring 2020 Cal Poly, Team S7-G6, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G6
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 137
