Ana içeriğe geç
Olympus 850SW Battery Latch Replacement
Neye ihtiyacın var
  1. Olympus 850SW Battery Latch Replacement, Battery Latch: adım 1, 1 resimden 1.
    • Locate the battery latch on the bottom of the device.
  2. Olympus 850SW Battery Latch Replacement: adım 2, 2 resimden 1. Olympus 850SW Battery Latch Replacement: adım 2, 2 resimden 2.
    • Unscrew the one screw on the latch.
    • Remove the screw.
  3. Olympus 850SW Battery Latch Replacement: adım 3, 1 resimden 1.
    • Remove the small black plastic piece positioned at the opening side of the battery latch.
  4. Olympus 850SW Battery Latch Replacement: adım 4, 1 resimden 1.
    • You will now be able to lift and remove the thin metal covering from battery latch.
  5. Olympus 850SW Battery Latch Replacement: adım 5, 1 resimden 1.
    • Open the latch.
  6. Olympus 850SW Battery Latch Replacement: adım 6, 1 resimden 1.
    • Locate the screw in the center crease of the opening of the battery latch.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 345
