Ana içeriğe geç
Olympus 850SW Battery Replacement
Neye ihtiyacın var
    1. Olympus 850SW Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Locate the battery compartment on the bottom panel of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Olympus 850SW Battery Replacement: adım 2, 2 resimden 1. Olympus 850SW Battery Replacement: adım 2, 2 resimden 2.
      • Using a PH00 Phillips Screwdriver, unscrew the one screw located on the latch.
      FixBot'a Sor
      Yorum Ekle
    3. Olympus 850SW Battery Replacement: adım 3, 3 resimden 1. Olympus 850SW Battery Replacement: adım 3, 3 resimden 2. Olympus 850SW Battery Replacement: adım 3, 3 resimden 3.
      • Find the arrows on the compartment, remove the small black plastic piece, and release the latch.
      FixBot'a Sor
      Yorum Ekle
    4. Olympus 850SW Battery Replacement: adım 4, 1 resimden 1.
      • Allow the latch to completely open and insert the battery, with the writing side up.
      • The battery slot is the bigger slot. The smaller slot is for the memory card.
      FixBot'a Sor
      Yorum Ekle
    5. Olympus 850SW Battery Replacement: adım 5, 1 resimden 1.
      • Close the latch. You will hear a click when the compartment is fully closed.
      FixBot'a Sor
      Yorum Ekle
    6. Olympus 850SW Battery Replacement: adım 6, 1 resimden 1.
      • Place the small black piece back in its' place.
      FixBot'a Sor
      Yorum Ekle
    7. Olympus 850SW Battery Replacement: adım 7, 1 resimden 1.
      • Place the metal cover back over the closed latch, and screw the screw back in.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 47
Her zaman: 1,469
