Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove five baseplate screws using a Phillips #00 screwdriver.
Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
Remove the single screw from the battery housing using a Phillips #00 screwdriver.
Using tweezers, lift the rubber plate to expose the ports.
Remove two screws from the ports using a Phillips #00 screwdriver.
Use a spudger to pry the faceplate away from the rest of the camera.
To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
Using a Phillips #00 screwdriver, remove three screws fastened to the camera backplate edge.
Using a Phillips #00 screwdriver, remove the two camera flash screws secured to either side of bulb housing component.
Using an iFixit opening tool, pry the backplate from the camera internal housing component.
Pull the backplate away from the camera internal housing component.
