Ana içeriğe geç
Olympus D590 Face Plate Replacement
Neye ihtiyacın var
  1. Olympus D590 Face Plate Replacement, Face Plate: adım 1, 1 resimden 1.
    • Remove five baseplate screws using a Phillips #00 screwdriver.
  2. Olympus D590 Face Plate Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
  3. Olympus D590 Face Plate Replacement: adım 3, 1 resimden 1.
    • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
  4. Olympus D590 Face Plate Replacement: adım 4, 1 resimden 1.
    • Using tweezers, lift the rubber plate to expose the ports.
  5. Olympus D590 Face Plate Replacement: adım 5, 1 resimden 1.
    • Remove two screws from the ports using a Phillips #00 screwdriver.
  6. Olympus D590 Face Plate Replacement: adım 6, 1 resimden 1.
    • Use a spudger to pry the faceplate away from the rest of the camera.
  7. Olympus D590 Face Plate Replacement: adım 7, 1 resimden 1.
    • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
    • Damage to the connector line will prevent the on/off power switch's operational function.
Sonuç
Katie
31 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 28-23, Regan Spring 2010 Cal Poly, Team 28-23, Regan Spring 2010 üyesi
CPSU-REGAN-S10S28G23
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 1,660
