Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Olympus D590 Face Plate Replacement
Neye ihtiyacın var
  1. Olympus D590 Face Plate Replacement, Face Plate: adım 1, 1 resimden 1.
    • Flip camera so you are looking at the bottom.
    • Unscrew all 5 base plate screws.
  2. Olympus D590 Face Plate Replacement: adım 2, 1 resimden 1.
    • Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
  3. Olympus D590 Face Plate Replacement: adım 3, 1 resimden 1.
    • Unscrew the single screw located next to the battery slot.
  4. Olympus D590 Face Plate Replacement: adım 4, 1 resimden 1.
    • Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
    • Lift the rubber plate exposing the ports beneath.
  5. Olympus D590 Face Plate Replacement: adım 5, 1 resimden 1.
    • Unscrew the 2 screws next to the USB and AC ports.
  6. Olympus D590 Face Plate Replacement: adım 6, 1 resimden 1.
    • Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
  7. Olympus D590 Face Plate Replacement: adım 7, 1 resimden 1.
    • Pull off the faceplate to reveal the inside of the camera.
    • Be careful of the connector that goes from the faceplate to the motherboard . Disconnecting this line will cause the camera not not power on through the on/off switch anymore.
Sonuç
Katie
31 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 28-23, Regan Spring 2010 Cal Poly, Team 28-23, Regan Spring 2010 üyesi
CPSU-REGAN-S10S28G23
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,600
