Ana içeriğe geç
Olympus D590 Retainer Clip Replacement
Neye ihtiyacın var
    1. Olympus D590 Retainer Clip Replacement, Face Plate: adım 1, 1 resimden 1.
      • Remove five baseplate screws using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Olympus D590 Retainer Clip Replacement: adım 2, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
      FixBot'a Sor
      Yorum Ekle
    3. Olympus D590 Retainer Clip Replacement: adım 3, 1 resimden 1.
      • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Olympus D590 Retainer Clip Replacement: adım 4, 1 resimden 1.
      • Using tweezers, lift the rubber plate to expose the ports.
      FixBot'a Sor
      Yorum Ekle
    5. Olympus D590 Retainer Clip Replacement: adım 5, 1 resimden 1.
      • Remove two screws from the ports using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Olympus D590 Retainer Clip Replacement: adım 6, 1 resimden 1.
      • Use a spudger to pry the faceplate away from the rest of the camera.
      FixBot'a Sor
      Yorum Ekle
    7. Olympus D590 Retainer Clip Replacement: adım 7, 1 resimden 1.
      • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
      • Damage to the connector line will prevent the on/off power switch's operational function.
      FixBot'a Sor
      Yorum Ekle
    1. Olympus D590 Retainer Clip Replacement, Retainer Clip: adım 8, 1 resimden 1.
      • Orient the camera as shown, with the bottom facing up.
      • Open the retainer clip, by using your finger to push down and slide to the left.
      • The clip should pop open.
      FixBot'a Sor
      Yorum Ekle
    2. Olympus D590 Retainer Clip Replacement: adım 9, 1 resimden 1.
      • Hold the retainer clip down (without re-latching it).
      • Use a flathead screwdriver to start to pry out the pin holding the retainer clip's spring to the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Olympus D590 Retainer Clip Replacement: adım 10, 1 resimden 1.
      • Use tweezers to continue to remove the pin.
      FixBot'a Sor
      Yorum Ekle
    4. Olympus D590 Retainer Clip Replacement: adım 11, 1 resimden 1.
      • When it feels loose, pull the pin all the way out with your fingers.
      FixBot'a Sor
      Yorum Ekle
    5. Olympus D590 Retainer Clip Replacement: adım 12, 1 resimden 1.
      • Once the pin comes out, the retainer clip, spring, and pin will no longer be attached to the rest of the camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Katie
31 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 28-23, Regan Spring 2010 Cal Poly, Team 28-23, Regan Spring 2010 üyesi
CPSU-REGAN-S10S28G23
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 2,560
