Ana içeriğe geç
Olympus FE-210 Lens Assembly Replacement
Neye ihtiyacın var
  1. Olympus FE-210 Lens Assembly Replacement, Battery: adım 1, 2 resimden 1. Olympus FE-210 Lens Assembly Replacement, Battery: adım 1, 2 resimden 2.
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
    FixBot'a Sor
    Yorum Ekle
  2. Olympus FE-210 Lens Assembly Replacement: adım 2, 2 resimden 1. Olympus FE-210 Lens Assembly Replacement: adım 2, 2 resimden 2.
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
    FixBot'a Sor
    Yorum Ekle
  3. Olympus FE-210 Lens Assembly Replacement, Front Casing: adım 3, 3 resimden 1. Olympus FE-210 Lens Assembly Replacement, Front Casing: adım 3, 3 resimden 2. Olympus FE-210 Lens Assembly Replacement, Front Casing: adım 3, 3 resimden 3.
    • Remove the seven screws holding the front case in place, with a Phillips #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
    FixBot'a Sor
    Yorum Ekle
  4. Olympus FE-210 Lens Assembly Replacement: adım 4, 3 resimden 1. Olympus FE-210 Lens Assembly Replacement: adım 4, 3 resimden 2. Olympus FE-210 Lens Assembly Replacement: adım 4, 3 resimden 3.
    • Insert an opening tool or spudger into the seam between the front case and body of the camera to release the clips holding it together.
    • These three places are located:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
    FixBot'a Sor
    Yorum Ekle
  5. Olympus FE-210 Lens Assembly Replacement, Rear Casing: adım 5, 1 resimden 1.
    • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Olympus FE-210 Lens Assembly Replacement: adım 6, 3 resimden 1. Olympus FE-210 Lens Assembly Replacement: adım 6, 3 resimden 2. Olympus FE-210 Lens Assembly Replacement: adım 6, 3 resimden 3.
    • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
    • Lift the white latch using a fingernail or a spudger.
    • Pull the cord from its connector.
    FixBot'a Sor
    Yorum Ekle
  7. Olympus FE-210 Lens Assembly Replacement, Motherboard: adım 7, 2 resimden 1. Olympus FE-210 Lens Assembly Replacement, Motherboard: adım 7, 2 resimden 2.
    • Remove the 2 pieces of translucent yellow tape.
    • Removing these pieces of tape will void the camera warranty. They serve no functional purpose and do not need to be replaced during reassembly.
    FixBot'a Sor
    Yorum Ekle
  8. Olympus FE-210 Lens Assembly Replacement: adım 8, 2 resimden 1. Olympus FE-210 Lens Assembly Replacement: adım 8, 2 resimden 2.
    • Remove the seven 2.7 mm using a #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Olympus FE-210 Lens Assembly Replacement: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the ribbon cord located near the top right corner of the motherboard. Do this by carefully pulling the cord out of the socket using a pair of tweezers.
    FixBot'a Sor
    Yorum Ekle
  10. Olympus FE-210 Lens Assembly Replacement: adım 10, 1 resimden 1.
    • Disconnect the ribbon cord located on the left side of the motherboard.
    • Use tweezers or a spudger to lift the latch on the connector.
    • Carefully remove the cord from the connector.
    FixBot'a Sor
    Yorum Ekle
  11. Olympus FE-210 Lens Assembly Replacement: adım 11, 2 resimden 1. Olympus FE-210 Lens Assembly Replacement: adım 11, 2 resimden 2.
    • De-solder the 2 connection points.
    • Be careful to not damage any part of the circuit board with the soldering iron.
    FixBot'a Sor
    Yorum Ekle
  12. Olympus FE-210 Lens Assembly Replacement: adım 12, 1 resimden 1.
    • Remove the motherboard from the camera casing.
    FixBot'a Sor
    Yorum Ekle
  13. Olympus FE-210 Lens Assembly Replacement, Lens Assembly: adım 13, 1 resimden 1.
    • Remove the three 3.6 mm screws using a #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  14. Olympus FE-210 Lens Assembly Replacement: adım 14, 2 resimden 1. Olympus FE-210 Lens Assembly Replacement: adım 14, 2 resimden 2.
    • Slide the lens to the left and pull up. The lens should easily come loose and slide right out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Matt
826 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-36, Regan Winter 2011 Cal Poly, Team 4-36, Regan Winter 2011 üyesi
CPSU-REGAN-W11S4G36
3 Üyeler
14 adet Kılavuz yazıldı
1Rehber Yorum
This is also applicable to the Olympus FE170. I dismantled and repaired mine using this guide. Excellent!
Alan Shaw - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 60
Her zaman: 7,269
