Giriş
The Olympus OM-D E-M10 Mark II dials or buttons replacement will depend on what dial or button is broken. Steps 1-3 are the same for all cases. Step 4 deviates depending on which button or dial is broken.
The underside of the group of three dials will all be exposed with the removal of the same circuit board. The underside of the lone dial on the opposite side of the camera is exposed by the removal of a different circuit board.
Neye ihtiyacın var
Lay the camera on its back as shown. Using the button located to the right of the lens, hold it down while rotating the lens to release it from the camera.
Open the battery door latch by moving the black button in the direction of the arrow, towards the camera screen.
Use a Phillips #00 screwdriver to remove two black 5.4 mm screws and one silver 2 mm screw from the viewfinder.
Remove the viewfinder from the camera carefully, being mindful of any ribbon cables that may still be attached to other components
Turn the camera upside down, and use a Phillips #00 screwdriver to remove one 4 mm screw from underneath the battery.
Turn the camera right side up, and remove two 6.4 mm screws from the top of the plastic frame.
Carefully remove the top plastic frame of the camera using fingers and a plastic spudger as needed.
