Ana içeriğe geç
Olympus OM-D E-M10 Mark II SD Card Replacement
  1. Olympus OM-D E-M10 Mark II SD Card Replacement, Battery: adım 1, 1 resimden 1.
    • Open the battery door latch by moving the black button in the direction of the arrow, towards the camera screen.
    • To ensure that the battery door is properly in the closed position, listen for an audible click.
  2. Olympus OM-D E-M10 Mark II SD Card Replacement: adım 2, 1 resimden 1.
    • Move the dark red latch towards the direction of the camera lens to release the battery from the camera.
    • Make sure the dark red latch blocks the battery from moving after placing the battery in the camera during reassembly.
  3. Olympus OM-D E-M10 Mark II SD Card Replacement: adım 3, 1 resimden 1.
    • You can now remove the battery from the body of the camera and begin reassembly with your new battery.
  4. Olympus OM-D E-M10 Mark II SD Card Replacement, SD Card: adım 4, 1 resimden 1.
    • Find the SD card located near the hinges of the door and gently press down on it so that it becomes free.
  5. Olympus OM-D E-M10 Mark II SD Card Replacement: adım 5, 1 resimden 1.
    • Remove the SD card from the camera by grabbing it with your fingers and lifting away from the camera.
Sonuç
To add your new SD card to your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Channing Pezet
214 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G6, Eyestone Spring 2018 USF Tampa, Team S5-G6, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S5G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 55
Her zaman: 2,735
