Ana içeriğe geç
Olympus SP-320 Back casing and LCD screen Replacement
Neye ihtiyacın var
  1. Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: adım 1, 3 resimden 1. Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: adım 1, 3 resimden 2. Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: adım 1, 3 resimden 3.
    • Remove the 3 mm long screws with a Phillips head screwdriver that has a PH000 size bit.
  2. Olympus SP-320 Back casing and LCD screen Replacement: adım 2, 1 resimden 1.
    • Remove the 3 mm long screw using Phillips head screwdriver that has a PH000 size bit.
  3. Olympus SP-320 Back casing and LCD screen Replacement: adım 3, 1 resimden 1.
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
  4. Olympus SP-320 Back casing and LCD screen Replacement: adım 4, 3 resimden 1. Olympus SP-320 Back casing and LCD screen Replacement: adım 4, 3 resimden 2. Olympus SP-320 Back casing and LCD screen Replacement: adım 4, 3 resimden 3.
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, plastic clip, detaching the ribbon from the main body of the camera.
  5. Olympus SP-320 Back casing and LCD screen Replacement: adım 5, 3 resimden 1. Olympus SP-320 Back casing and LCD screen Replacement: adım 5, 3 resimden 2. Olympus SP-320 Back casing and LCD screen Replacement: adım 5, 3 resimden 3.
    • You have detached the back casing and LCD screen.
Sonuç
Bir Yorum
Is that thin white connector - a powercable to screen led-light? thnx
Alex CalmCroft Tokarsky - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 526
