Ana içeriğe geç
Olympus SP-320 Motherboard Replacement
Neye ihtiyacın var
  1. Olympus SP-320 Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Olympus SP-320 Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Olympus SP-320 Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Remove the 3 mm long screws using a Phillips head screwdriver that has a PH000 size bit.
  2. Olympus SP-320 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the 3 mm long screw using a Phillips head screwdriver that has a PH000 size bit.
  3. Olympus SP-320 Motherboard Replacement: adım 3, 2 resimden 1. Olympus SP-320 Motherboard Replacement: adım 3, 2 resimden 2.
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
  4. Olympus SP-320 Motherboard Replacement: adım 4, 3 resimden 1. Olympus SP-320 Motherboard Replacement: adım 4, 3 resimden 2. Olympus SP-320 Motherboard Replacement: adım 4, 3 resimden 3.
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, white, plastic clip detaching the ribbon from the main body of the camera.
  5. Olympus SP-320 Motherboard Replacement: adım 5, 2 resimden 1. Olympus SP-320 Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove 2 mm long screws with the Phillips head screwdriver that has a PH000 size bit.
    • Remove 3 mm long screws with the Phillips head screwdriver that has a PH000 size bit.
  6. Olympus SP-320 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Nice description to follow!
Would you know which component is responsible in SP-320 for keeping the date/time while battery is out ?
Every time I remove the battery for replacement, the date/time settings is gone (instantly). Thanks!
Istvan Ujfalvi - Yanıt
It would be nice to know why you needed to access the motherboard.
John - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 517
