Giriş
In this guide you will learn to remove your camera's back case to expose the motherboard. While replacing the motherboard be very gentle. As you will see in the steps, there are internal ribbons that could easily be ripped or broken.
Neye ihtiyacın var
Remove the 3 mm long screws using a Phillips head screwdriver that has a PH000 size bit.
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Nice description to follow!
Would you know which component is responsible in SP-320 for keeping the date/time while battery is out ?
Every time I remove the battery for replacement, the date/time settings is gone (instantly). Thanks!
