Ana içeriğe geç
Olympus SZ-12 LCD Screen Replacement
Neye ihtiyacın var
  1. Olympus SZ-12 LCD Screen Replacement, Back Case: adım 1, 2 resimden 1. Olympus SZ-12 LCD Screen Replacement, Back Case: adım 1, 2 resimden 2.
    • Remove nine 4.45mm Phillips #000 screws from the outside of the case.
  2. Olympus SZ-12 LCD Screen Replacement: adım 2, 1 resimden 1.
    • There are four screws to take out on the bottom of the camera.
  3. Olympus SZ-12 LCD Screen Replacement: adım 3, 1 resimden 1.
    • There are three screws to take out on this side.
  4. Olympus SZ-12 LCD Screen Replacement: adım 4, 1 resimden 1.
    • There is one screw to take out on this side.
  5. Olympus SZ-12 LCD Screen Replacement: adım 5, 1 resimden 1.
    • There is one hidden screw inside the HDMI port.
  6. Olympus SZ-12 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Using the blue plastic opening tool, wedge open and remove the case.
  7. Olympus SZ-12 LCD Screen Replacement, LCD Screen: adım 7, 1 resimden 1.
    • Once you have the back case off, remove the LCD Screen.
  8. Olympus SZ-12 LCD Screen Replacement: adım 8, 1 resimden 1.
    • Using a plastic opening tool, gently lift the retaining flap on the display cable ZIF connector.
    • Pull the display cable from its socket on the motherboard.
  9. Olympus SZ-12 LCD Screen Replacement: adım 9, 1 resimden 1.
    • Remove the LCD screen from the device.
    • Be careful not to rip the display's ribbon cable as you pull the screen away from the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 14
Her zaman: 543
