Ana içeriğe geç
Olympus Stylus 1010 Flash Replacement
Neye ihtiyacın var
  1. Olympus Stylus 1010 Flash Replacement, Disassembling Olympus Stylus 1010 Case: adım 1, 2 resimden 1. Olympus Stylus 1010 Flash Replacement, Disassembling Olympus Stylus 1010 Case: adım 1, 2 resimden 2.
    • Remove the five Phillips #00 bottom and right side panel screws.
  2. Olympus Stylus 1010 Flash Replacement: adım 2, 1 resimden 1.
    • Remove the right side panel by pulling off the large silver piece.
  3. Olympus Stylus 1010 Flash Replacement: adım 3, 2 resimden 1. Olympus Stylus 1010 Flash Replacement: adım 3, 2 resimden 2.
    • Remove the remaining three Phillips #00 side and front panel screws.
  4. Olympus Stylus 1010 Flash Replacement: adım 4, 1 resimden 1.
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
  5. Olympus Stylus 1010 Flash Replacement: adım 5, 1 resimden 1.
    • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
  6. Olympus Stylus 1010 Flash Replacement: adım 6, 3 resimden 1. Olympus Stylus 1010 Flash Replacement: adım 6, 3 resimden 2. Olympus Stylus 1010 Flash Replacement: adım 6, 3 resimden 3.
    • Remove the three Phillips #00 screws from the front of the camera.
    • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
  7. Olympus Stylus 1010 Flash Replacement: adım 7, 3 resimden 1. Olympus Stylus 1010 Flash Replacement: adım 7, 3 resimden 2. Olympus Stylus 1010 Flash Replacement: adım 7, 3 resimden 3.
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
  8. Olympus Stylus 1010 Flash Replacement, Lens: adım 8, 2 resimden 1. Olympus Stylus 1010 Flash Replacement, Lens: adım 8, 2 resimden 2.
    • Still using the spudger, detach the three gold wire tape connectors from the inside of the camera.
  9. Olympus Stylus 1010 Flash Replacement: adım 9, 1 resimden 1.
    • Remove the three screws from the inside of the camera using a #00 screwdriver.
  10. Olympus Stylus 1010 Flash Replacement: adım 10, 2 resimden 1. Olympus Stylus 1010 Flash Replacement: adım 10, 2 resimden 2.
    • Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
  11. Olympus Stylus 1010 Flash Replacement, Motherboard: adım 11, 1 resimden 1.
    • Remove the two Phillips #00 screws on the right side of the camera.
  12. Olympus Stylus 1010 Flash Replacement: adım 12, 1 resimden 1.
    • Still using the spudger, detach the gold wire tape connectors from the motherboard.
  13. Olympus Stylus 1010 Flash Replacement: adım 13, 1 resimden 1.
    • Desolder the upper right and lower left wires to remove the motherboard.
  14. Olympus Stylus 1010 Flash Replacement: adım 14, 2 resimden 1. Olympus Stylus 1010 Flash Replacement: adım 14, 2 resimden 2.
    • In order to remove the motherboard, grab each side of it and pull up using your thumb and forefinger.
  15. Olympus Stylus 1010 Flash Replacement, Flash: adım 15, 3 resimden 1. Olympus Stylus 1010 Flash Replacement, Flash: adım 15, 3 resimden 2. Olympus Stylus 1010 Flash Replacement, Flash: adım 15, 3 resimden 3.
    • Remove the two remaining Phillips #00 screws.
    • Lift the metal piece straight up to remove it.
  16. Olympus Stylus 1010 Flash Replacement: adım 16, 3 resimden 1. Olympus Stylus 1010 Flash Replacement: adım 16, 3 resimden 2. Olympus Stylus 1010 Flash Replacement: adım 16, 3 resimden 3.
    • Pull gently on the white tab to remove the small motherboard with the flash device on it.
  17. Olympus Stylus 1010 Flash Replacement: adım 17, 2 resimden 1. Olympus Stylus 1010 Flash Replacement: adım 17, 2 resimden 2.
    • Pull out the silver button using your thumb and forefinger.
    • Remove the small motherboard from the camera casing.
  18. Olympus Stylus 1010 Flash Replacement: adım 18, 3 resimden 1. Olympus Stylus 1010 Flash Replacement: adım 18, 3 resimden 2. Olympus Stylus 1010 Flash Replacement: adım 18, 3 resimden 3.
    • Remove the plastic flash cover using a spudger.
  19. Olympus Stylus 1010 Flash Replacement: adım 19, 2 resimden 1. Olympus Stylus 1010 Flash Replacement: adım 19, 2 resimden 2.
    • Remove the flash bulb using a plastic spudger.
Sonuç
Curtis Reedy
267 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-4, Forte Winter 2011 Cal Poly, Team 13-4, Forte Winter 2011 üyesi
CPSU-FORTE-W11S13G4
6 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 2,564
