Giriş
This guide gives instructions on how to access and remove the lens from the Olympus Stylus 1010. Before proceeding make sure you have removed the case from the Olympus Stylus 1010.
Neye ihtiyacın var
Remove the five Phillips #00 bottom and right side panel screws.
Using a plastic spudger, lift up the black clips.
Still using the spudger, detach the three gold wire tape connectors from the inside of the camera.
2 farklı kişi bu kılavuzu tamamladı.
