Ana içeriğe geç
Olympus Stylus 1030 SW AV Port Replacement
Neye ihtiyacın var
  1. Olympus Stylus 1030 SW AV Port Replacement, AV Port: adım 1, 3 resimden 1. Olympus Stylus 1030 SW AV Port Replacement, AV Port: adım 1, 3 resimden 2. Olympus Stylus 1030 SW AV Port Replacement, AV Port: adım 1, 3 resimden 3.
    • Use your screwdriver with a Phillips #00 screwdriver to remove all three screws.
    • Use your hand to lift and remove the front case.
  2. Olympus Stylus 1030 SW AV Port Replacement: adım 2, 3 resimden 1. Olympus Stylus 1030 SW AV Port Replacement: adım 2, 3 resimden 2. Olympus Stylus 1030 SW AV Port Replacement: adım 2, 3 resimden 3.
    • Remove the rear case.
    • Use a Phillips #00 screwdriver to remove both screws from the side panel.
    • Remove both screws from the battery door.
  3. Olympus Stylus 1030 SW AV Port Replacement: adım 3, 1 resimden 1.
    • Flip the Olympus Stylus 1030 SW camera upside down, the rear side facing away from you.
  4. Olympus Stylus 1030 SW AV Port Replacement: adım 4, 2 resimden 1. Olympus Stylus 1030 SW AV Port Replacement: adım 4, 2 resimden 2.
    • Flip your camera with the rear side facing away from you. Take your screw driver with the #00 size to remove both screws.
    • Remove the front case.
  5. Olympus Stylus 1030 SW AV Port Replacement: adım 5, 3 resimden 1. Olympus Stylus 1030 SW AV Port Replacement: adım 5, 3 resimden 2. Olympus Stylus 1030 SW AV Port Replacement: adım 5, 3 resimden 3.
    • Start with the rear end facing away from you.
    • Use a Phillips #00 size to remove both screws.
    • Flip the camera to the front facing you.
    • Remove the single Phillips #00 screw.
  6. Olympus Stylus 1030 SW AV Port Replacement: adım 6, 3 resimden 1. Olympus Stylus 1030 SW AV Port Replacement: adım 6, 3 resimden 2. Olympus Stylus 1030 SW AV Port Replacement: adım 6, 3 resimden 3.
    • To get to the AV port use a spudger to separate the camera.
  7. Olympus Stylus 1030 SW AV Port Replacement: adım 7, 2 resimden 1. Olympus Stylus 1030 SW AV Port Replacement: adım 7, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the remaining two screws from the motherboard.
  8. Olympus Stylus 1030 SW AV Port Replacement: adım 8, 2 resimden 1. Olympus Stylus 1030 SW AV Port Replacement: adım 8, 2 resimden 2.
    • Use your fingers to lift the black flap and use a Phillips #00 screwdriver to remove the two screws.
  9. Olympus Stylus 1030 SW AV Port Replacement: adım 9, 2 resimden 1. Olympus Stylus 1030 SW AV Port Replacement: adım 9, 2 resimden 2.
    • With your tweezers from your kit, take out the motherboard of the camera.
    • Once the motherboard is removed separate the motherboard.
    • The AV port is visible, use your spatula to wedge between the AV port to remove.
Sonuç
Alexis Sulzle
301 İtibar
2 adet Kılavuz yazıldı
Ekip
Casper College, Team 1-4, Lareau Spring 2023 Casper College, Team 1-4, Lareau Spring 2023 üyesi
CASC-LAREAU-S23S1G4
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 57
