Ana içeriğe geç
Olympus Stylus 1030 SW Camera Lens Replacement
Neye ihtiyacın var
    1. Olympus Stylus 1030 SW Camera Lens Replacement, Olympus Stylus 1030 SW Camera Disassembly: adım 1, 3 resimden 1. Olympus Stylus 1030 SW Camera Lens Replacement, Olympus Stylus 1030 SW Camera Disassembly: adım 1, 3 resimden 2. Olympus Stylus 1030 SW Camera Lens Replacement, Olympus Stylus 1030 SW Camera Disassembly: adım 1, 3 resimden 3.
      • Using the iFixit Opening Tool, pry off the plastic part of the lens.
      • Using the T6 Torx screwdriver, unscrew the three screws.
      FixBot'a Sor
      Yorum Ekle
    2. Olympus Stylus 1030 SW Camera Lens Replacement: adım 2, 3 resimden 1. Olympus Stylus 1030 SW Camera Lens Replacement: adım 2, 3 resimden 2. Olympus Stylus 1030 SW Camera Lens Replacement: adım 2, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Using the Phillips #00 screwdriver, unscrew the three screws.
      • Carefully swivel the metal cover out towards you.
      • Using tweezers, remove the metal washer.
      FixBot'a Sor
      Yorum Ekle
    3. Olympus Stylus 1030 SW Camera Lens Replacement: adım 3, 2 resimden 1. Olympus Stylus 1030 SW Camera Lens Replacement: adım 3, 2 resimden 2.
      • Using the tweezers, slowly peel off the plate.
      FixBot'a Sor
      Yorum Ekle
    4. Olympus Stylus 1030 SW Camera Lens Replacement: adım 4, 3 resimden 1. Olympus Stylus 1030 SW Camera Lens Replacement: adım 4, 3 resimden 2. Olympus Stylus 1030 SW Camera Lens Replacement: adım 4, 3 resimden 3.
      • Using the Phillips #00 screwdriver, unscrew the two screws on the side of the camera.
      FixBot'a Sor
      Yorum Ekle
    5. Olympus Stylus 1030 SW Camera Lens Replacement: adım 5, 3 resimden 1. Olympus Stylus 1030 SW Camera Lens Replacement: adım 5, 3 resimden 2. Olympus Stylus 1030 SW Camera Lens Replacement: adım 5, 3 resimden 3.
      • On the opposite side, use the Phillips #00 screwdriver to unscrew both screws.
      • Take out the speaker plate.
      • Open the multi-connector cover and slide off the side panel.
      FixBot'a Sor
      Yorum Ekle
    6. Olympus Stylus 1030 SW Camera Lens Replacement: adım 6, 3 resimden 1. Olympus Stylus 1030 SW Camera Lens Replacement: adım 6, 3 resimden 2. Olympus Stylus 1030 SW Camera Lens Replacement: adım 6, 3 resimden 3.
      • Using the Phillips #00 screwdriver, unscrew the screw above the speaker.
      • On the bottom side of the camera, unscrew the two screws.
      FixBot'a Sor
      Yorum Ekle
    7. Olympus Stylus 1030 SW Camera Lens Replacement: adım 7, 3 resimden 1. Olympus Stylus 1030 SW Camera Lens Replacement: adım 7, 3 resimden 2. Olympus Stylus 1030 SW Camera Lens Replacement: adım 7, 3 resimden 3.
      • Open the battery compartment cover.
      • Use the Phillips #00 screwdriver to unscrew the screw in the battery compartment.
      FixBot'a Sor
      Yorum Ekle
    8. Olympus Stylus 1030 SW Camera Lens Replacement: adım 8, 3 resimden 1. Olympus Stylus 1030 SW Camera Lens Replacement: adım 8, 3 resimden 2. Olympus Stylus 1030 SW Camera Lens Replacement: adım 8, 3 resimden 3.
      • On the front of the camera, unscrew the two screws shown.
      • Gently pull on the side until the camera is separated from the back panel.
      • Remove the shutter and power button.
      FixBot'a Sor
      Yorum Ekle
    9. Olympus Stylus 1030 SW Camera Lens Replacement: adım 9, 3 resimden 1. Olympus Stylus 1030 SW Camera Lens Replacement: adım 9, 3 resimden 2. Olympus Stylus 1030 SW Camera Lens Replacement: adım 9, 3 resimden 3.
      • Use the Phillips #00 screwdriver to unscrew the four screws on the front of the camera.
      • Unscrew the shutter using the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    10. Olympus Stylus 1030 SW Camera Lens Replacement: adım 10, 2 resimden 1. Olympus Stylus 1030 SW Camera Lens Replacement: adım 10, 2 resimden 2.
      • Release the top holding using a spudger.
      • Slowly and carefully separate the front and back of the camera, exposing the electrical ribbons.
      FixBot'a Sor
      Yorum Ekle
    11. Olympus Stylus 1030 SW Camera Lens Replacement: adım 11, 3 resimden 1. Olympus Stylus 1030 SW Camera Lens Replacement: adım 11, 3 resimden 2. Olympus Stylus 1030 SW Camera Lens Replacement: adım 11, 3 resimden 3.
      • Using the spudger and tweezers if needed, remove the ribbons from the computer chips.
      FixBot'a Sor
      Yorum Ekle
    1. Olympus Stylus 1030 SW Camera Lens Replacement, Camera Lens: adım 12, 3 resimden 1. Olympus Stylus 1030 SW Camera Lens Replacement, Camera Lens: adım 12, 3 resimden 2. Olympus Stylus 1030 SW Camera Lens Replacement, Camera Lens: adım 12, 3 resimden 3.
      • Peel off the black tape using tweezers.
      • Unscrew the 1.0 cm screw.
      • Use the spudger to carefully take out the lens compartment.
      FixBot'a Sor
      Yorum Ekle
    2. Olympus Stylus 1030 SW Camera Lens Replacement: adım 13, 2 resimden 1. Olympus Stylus 1030 SW Camera Lens Replacement: adım 13, 2 resimden 2.
      • Carefully take out the lens and the black plastic pieces along with it.
      FixBot'a Sor
      Yorum Ekle
    3. Olympus Stylus 1030 SW Camera Lens Replacement: adım 14, 3 resimden 1. Olympus Stylus 1030 SW Camera Lens Replacement: adım 14, 3 resimden 2. Olympus Stylus 1030 SW Camera Lens Replacement: adım 14, 3 resimden 3.
      • Unscrew the three screws found on top of the mirror lens.
      • The mirror lens can now be removed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 40
Her zaman: 1,653
