Ana içeriğe geç
Olympus Stylus 1030 SW Flash Assembly Replacement
Neye ihtiyacın var
  1. Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: adım 1, 3 resimden 1. Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: adım 1, 3 resimden 2. Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: adım 1, 3 resimden 3.
    • Remove the three screws in the corner of the front plate using a Phillips #00 screwdriver.
    • Lift up on the plate until it comes off the rest of the camera.
  2. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 2, 3 resimden 1. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 2, 3 resimden 2. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 2, 3 resimden 3.
    • Use the Phillips #00 screwdriver to remove the two screws on both of the side plates of the camera.
  3. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 3, 1 resimden 1.
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera.
  4. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 4, 2 resimden 1. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 4, 2 resimden 2.
    • Turn the camera so the short side without the av port is facing you.
    • Remove both of the screws on this side using the Phillips #00 screwdriver.
    • Remove the front case.
  5. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 5, 3 resimden 1. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 5, 3 resimden 2. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 5, 3 resimden 3.
    • Face the camera so the short side with the AV port facing you. Use your Phillips #00 screwdriver to remove the single screw.
    • Turn your camera so the other short side is facing you. Use the Phillips #00 screwdriver to remove the two screws on the silver parts.
    • Face the bottom of your camera towards you and remove the single screw using the Phillips #00 screwdriver.
  6. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 6, 3 resimden 1. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 6, 3 resimden 2. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 6, 3 resimden 3.
    • Open the battery door and use your Phillips #00 screwdriver to remove the screw in the middle of the opening.
    • Use the spudger to pry at the rear case until it comes off.
  7. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 7, 2 resimden 1. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 7, 2 resimden 2.
    • Flip the camera so the front is facing you.
    • Use your Phillips #00 screwdriver to remove the three screws located in the corners on this side.
  8. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 8, 1 resimden 1.
    • Turn the camera so you are looking at the top.
    • Use your Phillips #00 screwdriver to remove the single screw.
  9. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 9, 3 resimden 1. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 9, 3 resimden 2. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 9, 3 resimden 3.
    • Use your spudger to gently pry at the side of the LCD screen and the cover over it.
    • Gently take it apart, using caution with the motherboard and battery.
  10. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 10, 3 resimden 1. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 10, 3 resimden 2. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 10, 3 resimden 3.
    • Use your Phillips #00 screwdriver to remove the three screws.
  11. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 11, 3 resimden 1. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 11, 3 resimden 2. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 11, 3 resimden 3.
  12. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 12, 1 resimden 1.
    • Pull the foam to the side gently and use your Phillips #00 screwdriver to remove the single screw.
  13. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 13, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use your tweezers to gently pull the motherboard out of the camera.
  14. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 14, 2 resimden 1. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 14, 2 resimden 2.
    • Use your Phillips #00 screwdriver to remove the two screws holding the wires to the flash assembly.
  15. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 15, 2 resimden 1. Olympus Stylus 1030 SW Flash Assembly Replacement: adım 15, 2 resimden 2.
    • Use your tweezers to gently remove the last wires connected to the flash assembly.
Sonuç
Paige Asmus
241 İtibar
1 Kılavuz yazıldı
Ekip
Casper College, Team 1-4, Lareau Spring 2023 Casper College, Team 1-4, Lareau Spring 2023 üyesi
CASC-LAREAU-S23S1G4
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 60
