Ana içeriğe geç
Olympus Stylus 1030 SW Motherboard Replacement
Neye ihtiyacın var
  1. Olympus Stylus 1030 SW Motherboard Replacement, Olympus Stylus 1030 SW Camera Disassembly: adım 1, 3 resimden 1. Olympus Stylus 1030 SW Motherboard Replacement, Olympus Stylus 1030 SW Camera Disassembly: adım 1, 3 resimden 2. Olympus Stylus 1030 SW Motherboard Replacement, Olympus Stylus 1030 SW Camera Disassembly: adım 1, 3 resimden 3.
    • Using the iFixit Opening Tool, pry off the plastic part of the lens.
    • Using the T6 Torx screwdriver, unscrew the three screws.
  2. Olympus Stylus 1030 SW Motherboard Replacement: adım 2, 3 resimden 1. Olympus Stylus 1030 SW Motherboard Replacement: adım 2, 3 resimden 2. Olympus Stylus 1030 SW Motherboard Replacement: adım 2, 3 resimden 3.
    • Using the Phillips #00 screwdriver, unscrew the three screws.
    • Carefully swivel the metal cover out towards you.
    • Using tweezers, remove the metal washer.
  3. Olympus Stylus 1030 SW Motherboard Replacement: adım 3, 2 resimden 1. Olympus Stylus 1030 SW Motherboard Replacement: adım 3, 2 resimden 2.
    • Using the tweezers, slowly peel off the plate.
  4. Olympus Stylus 1030 SW Motherboard Replacement: adım 4, 3 resimden 1. Olympus Stylus 1030 SW Motherboard Replacement: adım 4, 3 resimden 2. Olympus Stylus 1030 SW Motherboard Replacement: adım 4, 3 resimden 3.
    • Using the Phillips #00 screwdriver, unscrew the two screws on the side of the camera.
  5. Olympus Stylus 1030 SW Motherboard Replacement: adım 5, 3 resimden 1. Olympus Stylus 1030 SW Motherboard Replacement: adım 5, 3 resimden 2. Olympus Stylus 1030 SW Motherboard Replacement: adım 5, 3 resimden 3.
    • On the opposite side, use the Phillips #00 screwdriver to unscrew both screws.
    • Take out the speaker plate.
    • Open the multi-connector cover and slide off the side panel.
  6. Olympus Stylus 1030 SW Motherboard Replacement: adım 6, 3 resimden 1. Olympus Stylus 1030 SW Motherboard Replacement: adım 6, 3 resimden 2. Olympus Stylus 1030 SW Motherboard Replacement: adım 6, 3 resimden 3.
    • Using the Phillips #00 screwdriver, unscrew the screw above the speaker.
    • On the bottom side of the camera, unscrew the two screws.
  7. Olympus Stylus 1030 SW Motherboard Replacement: adım 7, 3 resimden 1. Olympus Stylus 1030 SW Motherboard Replacement: adım 7, 3 resimden 2. Olympus Stylus 1030 SW Motherboard Replacement: adım 7, 3 resimden 3.
    • Open the battery compartment cover.
    • Use the Phillips #00 screwdriver to unscrew the screw in the battery compartment.
  8. Olympus Stylus 1030 SW Motherboard Replacement: adım 8, 3 resimden 1. Olympus Stylus 1030 SW Motherboard Replacement: adım 8, 3 resimden 2. Olympus Stylus 1030 SW Motherboard Replacement: adım 8, 3 resimden 3.
    • On the front of the camera, unscrew the two screws shown.
    • Gently pull on the side until the camera is separated from the back panel.
    • Remove the shutter and power button.
  9. Olympus Stylus 1030 SW Motherboard Replacement: adım 9, 3 resimden 1. Olympus Stylus 1030 SW Motherboard Replacement: adım 9, 3 resimden 2. Olympus Stylus 1030 SW Motherboard Replacement: adım 9, 3 resimden 3.
    • Use the Phillips #00 screwdriver to unscrew the four screws on the front of the camera.
    • Unscrew the shutter using the Phillips #00 screwdriver.
  10. Olympus Stylus 1030 SW Motherboard Replacement: adım 10, 2 resimden 1. Olympus Stylus 1030 SW Motherboard Replacement: adım 10, 2 resimden 2.
    • Release the top holding using a spudger.
    • Slowly and carefully separate the front and back of the camera, exposing the electrical ribbons.
  11. Olympus Stylus 1030 SW Motherboard Replacement: adım 11, 3 resimden 1. Olympus Stylus 1030 SW Motherboard Replacement: adım 11, 3 resimden 2. Olympus Stylus 1030 SW Motherboard Replacement: adım 11, 3 resimden 3.
    • Using the spudger and tweezers if needed, remove the ribbons from the computer chips.
  12. Olympus Stylus 1030 SW Motherboard Replacement, Motherboard: adım 12, 3 resimden 1. Olympus Stylus 1030 SW Motherboard Replacement, Motherboard: adım 12, 3 resimden 2. Olympus Stylus 1030 SW Motherboard Replacement, Motherboard: adım 12, 3 resimden 3.
    • Remove the 1.0 cm and the 0.8 mm screws.
    • Peel off tape and remove ribbons.
    • Remove black plastic cover and unscrew the 1.1 cm screw.
  13. Olympus Stylus 1030 SW Motherboard Replacement: adım 13, 2 resimden 1. Olympus Stylus 1030 SW Motherboard Replacement: adım 13, 2 resimden 2.
    • Release ribbons carefully using either tweezers or a spudger.
    • Remove the 1.1 cm screw.
  14. Olympus Stylus 1030 SW Motherboard Replacement: adım 14, 3 resimden 1. Olympus Stylus 1030 SW Motherboard Replacement: adım 14, 3 resimden 2. Olympus Stylus 1030 SW Motherboard Replacement: adım 14, 3 resimden 3.
    • Push A/V port away from you carefully using a spudger.
    • Slowly take out the motherboard and the speaker microphone.
    • Collect the metal washer plate from the top right corner of the motherboard (now loose).
  15. Olympus Stylus 1030 SW Motherboard Replacement: adım 15, 2 resimden 1. Olympus Stylus 1030 SW Motherboard Replacement: adım 15, 2 resimden 2.
    • With a spudger or finger, slowly take out the battery hinged to the motherboard.
    • Be careful not to disconnect the wires by pulling it too hard.
    • Take out motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
3 Yorum
what is the voltage, and capacitance of the main flash capacitor? diameter and length? I want to replace mine as my 'flash charging' symbol constantly flashes and flash does not fire.
thanks for the writeup! I have more confidence in repairing my 10+ year old camera
Kevin Kay - Yanıt
the cap is 330uF and 90V
dimensions:
11.94mm diameter
25.65mm length
Kevin Kay - Yanıt
How would I go about extracting the camera module and hooking it up to an arduino?
My cam got saltwater damage however it still turns on for a few seconds before turning off again
GoodNight Tea - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,091
