Ana içeriğe geç
Giriş
If the battery cover on your Olympus Stylus 410 digital camera has broken off, or is damaged, use this guide to remove it and replace with a new one.
Parçalar
Hiçbir parça belirtilmedi.
  1. Locate the 2 screws on the bottom of the slider.
    • Locate the 2 screws on the bottom of the slider.
    • Remove both screws with a #00 Phillips screwdriver.
  2. Gently pull on the bottom of the slider until it comes off the lower track.
    • Gently pull on the bottom of the slider until it comes off the lower track.
    • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
  3. Lift the slider up until it comes off the upper track.
    • Lift the slider up until it comes off the upper track.
  4. The slider should now be free from the body of the camera.
    • The slider should now be free from the body of the camera.
  5. Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver. Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver. Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
    • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  6. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  7. Use the spudger to peel off the outer metal band, starting from the bottom of the camera. The metal band it attached to the camera with glue in addition to screws.  Be careful not to bend the band when removing it from the camera.
    • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
    • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
  8. The shutter button can now be removed. It is not connected to the camera and can be lifted off. The shutter button can now be removed. It is not connected to the camera and can be lifted off.
    • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
  9. Remove the memory card. Locate and remove the 2 screws using a #00 Phillips screwdriver.
    • Remove the memory card.
    • Locate and remove the 2 screws using a #00 Phillips screwdriver.
  10. Use a spudger around the edge of the case to loosen it. Carefully wiggle the back case off. This may require a fair amount of force. Carefully wiggle the back case off. This may require a fair amount of force.
    • Use a spudger around the edge of the case to loosen it.
    • Carefully wiggle the back case off. This may require a fair amount of force.
  11. Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
    • Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
  12. While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required. Be careful not to completely pull the front case off because it will still be connected with wires.
    • While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
    • Be careful not to completely pull the front case off because it will still be connected with wires.
  13. Open the battery cover and lift it up and off of back camera case. Open the battery cover and lift it up and off of back camera case.
    • Open the battery cover and lift it up and off of back camera case.
  14. Locate and unscrew the 2 screws with a #00 Phillips screwdriver. Remove the black seal. Remove the black seal.
    • Locate and unscrew the 2 screws with a #00 Phillips screwdriver.
    • Remove the black seal.
  15. Slide the metal piece off of the battery cover. Slide the metal piece off of the battery cover.
    • Slide the metal piece off of the battery cover.
  16. This is what the battery cover and back case look like completely disassembled.
    • This is what the battery cover and back case look like completely disassembled.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Rory Aronson
34 İtibar
6 adet Kılavuz yazıldı
Takım
Cal Poly, Team 6-13, Maness Spring 2010 Cal Poly, Team 6-13, Maness Spring 2010 üyesi
CPSU-MANESS-S10S6G13
5 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
i need Battery where i can find it thinks
Olympus Stylus 410 Battery
uae20162017 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 3
Her zaman: 2,512
