Giriş
If the flash on your Olympus Stylus 410 no longer works, use this guide to replace it.
Neye ihtiyacın var
Locate the 2 screws on the bottom of the slider.
Remove both screws with a #00 Phillips screwdriver.
Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
Locate the gray compartment covering the flash.
Position your flat head screw driver or small spudger underneath the tab that is keeping the gray cover on.
Gently lift the tab so the gray compartment becomes free.
2 Yorum
Good instructions, but author doesn't say where or how to get new flash unit!
Ken Arnoldi
Good instructions but author doesn't say how or where to get new flash unit!
