Ana içeriğe geç
Olympus Stylus 410 LCD Screen Replacement
Neye ihtiyacın var
    1. Olympus Stylus 410 LCD Screen Replacement, Slider: adım 1, 1 resimden 1.
      • Locate the 2 screws on the bottom of the slider.
      • Remove both screws with a #00 Phillips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Olympus Stylus 410 LCD Screen Replacement: adım 2, 1 resimden 1.
      • Gently pull on the bottom of the slider until it comes off the lower track.
      • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
      FixBot'a Sor
      Yorum Ekle
    3. Olympus Stylus 410 LCD Screen Replacement: adım 3, 1 resimden 1.
      • Lift the slider up until it comes off the upper track.
      FixBot'a Sor
      Yorum Ekle
    4. Olympus Stylus 410 LCD Screen Replacement: adım 4, 1 resimden 1.
      • The slider should now be free from the body of the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Olympus Stylus 410 LCD Screen Replacement, Outer Case: adım 5, 3 resimden 1. Olympus Stylus 410 LCD Screen Replacement, Outer Case: adım 5, 3 resimden 2. Olympus Stylus 410 LCD Screen Replacement, Outer Case: adım 5, 3 resimden 3.
      • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Olympus Stylus 410 LCD Screen Replacement: adım 6, 2 resimden 1. Olympus Stylus 410 LCD Screen Replacement: adım 6, 2 resimden 2.
      • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
      • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Olympus Stylus 410 LCD Screen Replacement: adım 7, 2 resimden 1. Olympus Stylus 410 LCD Screen Replacement: adım 7, 2 resimden 2.
      • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
      FixBot'a Sor
      Yorum Ekle
    4. Olympus Stylus 410 LCD Screen Replacement: adım 8, 2 resimden 1. Olympus Stylus 410 LCD Screen Replacement: adım 8, 2 resimden 2.
      • Remove the memory card.
      • Locate and remove the 2 screws using a #00 Phillips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Olympus Stylus 410 LCD Screen Replacement: adım 9, 3 resimden 1. Olympus Stylus 410 LCD Screen Replacement: adım 9, 3 resimden 2. Olympus Stylus 410 LCD Screen Replacement: adım 9, 3 resimden 3.
      • Use a spudger around the edge of the case to loosen it.
      • Carefully wiggle the back case off. This may require a fair amount of force.
      FixBot'a Sor
      Yorum Ekle
    6. Olympus Stylus 410 LCD Screen Replacement: adım 10, 1 resimden 1.
      • Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    7. Olympus Stylus 410 LCD Screen Replacement: adım 11, 2 resimden 1. Olympus Stylus 410 LCD Screen Replacement: adım 11, 2 resimden 2.
      • While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
      • Be careful not to completely pull the front case off because it will still be connected with wires.
      FixBot'a Sor
      Yorum Ekle
    1. Olympus Stylus 410 LCD Screen Replacement, LCD Screen: adım 12, 3 resimden 1. Olympus Stylus 410 LCD Screen Replacement, LCD Screen: adım 12, 3 resimden 2. Olympus Stylus 410 LCD Screen Replacement, LCD Screen: adım 12, 3 resimden 3.
      • Remove the metal frame from the LCD screen using an opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. Olympus Stylus 410 LCD Screen Replacement: adım 13, 3 resimden 1. Olympus Stylus 410 LCD Screen Replacement: adım 13, 3 resimden 2. Olympus Stylus 410 LCD Screen Replacement: adım 13, 3 resimden 3.
      • Pry off the LCD screen from the top using an opening tool.
      • Do not pull the screen completely off because it will still be held on by two ribbon cables.
      FixBot'a Sor
      Yorum Ekle
    3. Olympus Stylus 410 LCD Screen Replacement: adım 14, 1 resimden 1.
      • This is what the camera will look like now that the LCD screen is removed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Rory Aronson
82 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-13, Maness Spring 2010 Cal Poly, Team 6-13, Maness Spring 2010 üyesi
CPSU-MANESS-S10S6G13
5 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 48
Her zaman: 4,717
