Ana içeriğe geç
Olympus Stylus 410 Shutter Button Replacement
Neye ihtiyacın var
  1. Olympus Stylus 410 Shutter Button Replacement, Shutter Button: adım 1, 3 resimden 1. Olympus Stylus 410 Shutter Button Replacement, Shutter Button: adım 1, 3 resimden 2. Olympus Stylus 410 Shutter Button Replacement, Shutter Button: adım 1, 3 resimden 3.
    • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  2. Olympus Stylus 410 Shutter Button Replacement: adım 2, 2 resimden 1. Olympus Stylus 410 Shutter Button Replacement: adım 2, 2 resimden 2.
    • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
    • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
  3. Olympus Stylus 410 Shutter Button Replacement: adım 3, 2 resimden 1. Olympus Stylus 410 Shutter Button Replacement: adım 3, 2 resimden 2.
    • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
Sonuç
Rory Aronson
46 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-13, Maness Spring 2010 Cal Poly, Team 6-13, Maness Spring 2010 üyesi
CPSU-MANESS-S10S6G13
5 Üyeler
17 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 3,137
