Ana içeriğe geç
Olympus Stylus 725 SW Lens Replacement
Neye ihtiyacın var
  1. Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: adım 1, 3 resimden 1. Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: adım 1, 3 resimden 2. Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: adım 1, 3 resimden 3.
    • Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
    • Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Olympus Stylus 725 SW Lens Replacement: adım 2, 2 resimden 1. Olympus Stylus 725 SW Lens Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Be careful when removing the back cover; you will need to detach the connecting ribbons. Use tweezers if necessary.
    • Detach the ribbons using your thumb, sliding them out of their slots.
    • Set the back panel face up to keep the ribbons from touching anything.
    FixBot'a Sor
    Yorum Ekle
  3. Olympus Stylus 725 SW Lens Replacement, Front Panel: adım 3, 3 resimden 1. Olympus Stylus 725 SW Lens Replacement, Front Panel: adım 3, 3 resimden 2. Olympus Stylus 725 SW Lens Replacement, Front Panel: adım 3, 3 resimden 3.
    • Remove the top screws using a 1.5 mm screwdriver.
    • Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Olympus Stylus 725 SW Lens Replacement, Side Panels: adım 4, 3 resimden 1. Olympus Stylus 725 SW Lens Replacement, Side Panels: adım 4, 3 resimden 2. Olympus Stylus 725 SW Lens Replacement, Side Panels: adım 4, 3 resimden 3.
    • Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
    FixBot'a Sor
    Yorum Ekle
  5. Olympus Stylus 725 SW Lens Replacement: adım 5, 3 resimden 1. Olympus Stylus 725 SW Lens Replacement: adım 5, 3 resimden 2. Olympus Stylus 725 SW Lens Replacement: adım 5, 3 resimden 3.
    • After removing all four of the screws, pry the side covers off of the camera.
    FixBot'a Sor
    Yorum Ekle
  6. Olympus Stylus 725 SW Lens Replacement, Lens: adım 6, 3 resimden 1. Olympus Stylus 725 SW Lens Replacement, Lens: adım 6, 3 resimden 2. Olympus Stylus 725 SW Lens Replacement, Lens: adım 6, 3 resimden 3.
    • Unscrew four 2mm long screws using the #00 Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Olympus Stylus 725 SW Lens Replacement: adım 7, 3 resimden 1. Olympus Stylus 725 SW Lens Replacement: adım 7, 3 resimden 2. Olympus Stylus 725 SW Lens Replacement: adım 7, 3 resimden 3.
    • Remove four metal tabs from corners where the 2mm long screws were attached using tweezers.
    FixBot'a Sor
    Yorum Ekle
  8. Olympus Stylus 725 SW Lens Replacement: adım 8, 2 resimden 1. Olympus Stylus 725 SW Lens Replacement: adım 8, 2 resimden 2.
    • Remove the viewfinder lens using a prying device.
    • There will be two ribbons attached to the viewfinder. Remove the ribbons by sliding them off the viewfinder with your thumb.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bobby Hodges
49 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 33-71, Johann Spring 2010 Cal Poly, Team 33-71, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S33G71
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 45
Her zaman: 5,062
