Ana içeriğe geç
Olympus Stylus 760 Case Replacement
Neye ihtiyacın var
  1. Olympus Stylus 760 Case Replacement, Case: adım 1, 1 resimden 1.
    • Remove the 2 screws from the bottom of the camera
  2. Olympus Stylus 760 Case Replacement: adım 2, 1 resimden 1.
    • Remove the screw from the right side of the camera.
  3. Olympus Stylus 760 Case Replacement: adım 3, 1 resimden 1.
    • Remove the two screws from the left side of the camera
  4. Olympus Stylus 760 Case Replacement: adım 4, 3 resimden 1. Olympus Stylus 760 Case Replacement: adım 4, 3 resimden 2. Olympus Stylus 760 Case Replacement: adım 4, 3 resimden 3.
    • Separate the front casing from the back using a plastic opening tool, gently.
    • Silver band and buttons will become loose when you remove the two pieces.
  5. Olympus Stylus 760 Case Replacement: adım 5, 2 resimden 1. Olympus Stylus 760 Case Replacement: adım 5, 2 resimden 2.
    • Pull the silver bracket and buttons off of the camera
  6. Olympus Stylus 760 Case Replacement: adım 6, 3 resimden 1. Olympus Stylus 760 Case Replacement: adım 6, 3 resimden 2. Olympus Stylus 760 Case Replacement: adım 6, 3 resimden 3.
    • Remove the 2 screws on the right side of the camera.
    • Remove the 2 screws on the left side of the camera.
    • Circuit ribbon is attached at the top-left of the camera. Be careful when separating the front and back of the camera.
    • Pull the camera apart into 2 separate pieces.
  7. Olympus Stylus 760 Case Replacement: adım 7, 1 resimden 1.
    • Flip up clip on circuit ribbon, carefully
    • Detach the ribbon from the rear to the front and pull it out, gently.
  8. Olympus Stylus 760 Case Replacement: adım 8, 1 resimden 1.
    • You will be left with four major pieces
Sonuç
Tracy Donovan
13 İtibar
1 Kılavuz yazıldı
Ekip
James Madison, Team 3-3, Klein Spring 2012 James Madison, Team 3-3, Klein Spring 2012 üyesi
JMU-KLEIN-S12S3G3
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 936
