Ana içeriğe geç
Olympus Stylus 760 LCD Screen Replacement
Neye ihtiyacın var
  1. Olympus Stylus 760 LCD Screen Replacement, Battery door: adım 1, 1 resimden 1.
    • Slide the door located on the bottom of the camera in an outward direction
  2. Olympus Stylus 760 LCD Screen Replacement, Release: adım 2, 1 resimden 1.
    • Pull back on the red release tab located on the left side of the battery.
  3. Olympus Stylus 760 LCD Screen Replacement, Replacement: adım 3, 1 resimden 1.
    • Slide battery out of camera
  4. Olympus Stylus 760 LCD Screen Replacement, LCD Screen: adım 4, 1 resimden 1.
    • Remove the 2 screws from the bottom of the camera
  5. Olympus Stylus 760 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Using a Phillips head size 0 screwdriver, remove the screw from the right side of the camera
  6. Olympus Stylus 760 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Remove the 2 screws from the left side of the camera
  7. Olympus Stylus 760 LCD Screen Replacement: adım 7, 3 resimden 1. Olympus Stylus 760 LCD Screen Replacement: adım 7, 3 resimden 2. Olympus Stylus 760 LCD Screen Replacement: adım 7, 3 resimden 3.
    • Separate the front casing from the back using a plastic opening tool, gently.
    • Silver band and buttons will become loose when you remove the two pieces.
  8. Olympus Stylus 760 LCD Screen Replacement: adım 8, 2 resimden 1. Olympus Stylus 760 LCD Screen Replacement: adım 8, 2 resimden 2.
    • Pull the silver bracket off of the camera
  9. Olympus Stylus 760 LCD Screen Replacement: adım 9, 3 resimden 1. Olympus Stylus 760 LCD Screen Replacement: adım 9, 3 resimden 2. Olympus Stylus 760 LCD Screen Replacement: adım 9, 3 resimden 3.
    • Remove the 4 screws on the inner face of the camera.
    • Circuit ribbon is attached at the top left of the camera. Be careful when separating the front and back of the camera.
    • Pull the camera apart into 2 separate pieces.
  10. Olympus Stylus 760 LCD Screen Replacement: adım 10, 1 resimden 1.
    • You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
  11. Olympus Stylus 760 LCD Screen Replacement: adım 11, 2 resimden 1. Olympus Stylus 760 LCD Screen Replacement: adım 11, 2 resimden 2.
    • Remove 4 screws holding the LCD screen in place.
    • Be cautious of the brackets that come loose when you remove the 3 screws on the right side of the camera
    • LCD Screen is attached to 2 ribbon wires
  12. Olympus Stylus 760 LCD Screen Replacement: adım 12, 2 resimden 1. Olympus Stylus 760 LCD Screen Replacement: adım 12, 2 resimden 2.
    • Pull up on the small ribbon wire to disconnect it from the circuit board
    • Flip the little black clip up to remove the larger ribbon wire from the circuit board.
  13. Olympus Stylus 760 LCD Screen Replacement: adım 13, 1 resimden 1.
    • Using a plastic separating tool, remove the LCD screen from the plastic casing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Cosgrove
39 İtibar
1 Kılavuz yazıldı
Ekip
James Madison, Team 3-3, Klein Spring 2012 James Madison, Team 3-3, Klein Spring 2012 üyesi
JMU-KLEIN-S12S3G3
4 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
from where i can get repaired u760 camera
tahir zafar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 1,773
