Ana içeriğe geç
Olympus Stylus Tough-6000 Lens Cover Replacement
Neye ihtiyacın var
  1. Olympus Stylus Tough-6000 Lens Cover Replacement, Disassemble Camera.: adım 1, 1 resimden 1.
    • You will want to disassemble the camera to get to the Lens Cover.
  2. Olympus Stylus Tough-6000 Lens Cover Replacement: adım 2, 1 resimden 1.
    • There are two screws on the right side of the camera.
    • Use your Phillips #00 screwdriver and unscrew both screws.
  3. Olympus Stylus Tough-6000 Lens Cover Replacement: adım 3, 1 resimden 1.
    • On the left side of the camera there will be another set of screws.
    • Unscrew both screws with the same Phillips #00 screwdriver.
  4. Olympus Stylus Tough-6000 Lens Cover Replacement: adım 4, 1 resimden 1.
    • After unscrewing the screws on the left side of the camera you will notice a speaker hat.
    • You will be able to pull the speaker hat off.
    • You must pull the speaker hat off to be able to pry the front shell of the camera apart.
  5. Olympus Stylus Tough-6000 Lens Cover Replacement: adım 5, 1 resimden 1.
    • Grab your plastic opening tool and begin to pry off the front shell of the camera.
    • The front shell will easily come off after a couple of prys.
  6. Olympus Stylus Tough-6000 Lens Cover Replacement: adım 6, 1 resimden 1.
    • Once you have the camera shell cover off you can see the lens cover.
    • Unscrew the lens cover with your Phillips #00 screwdriver to replace it with a new lens cover.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Shannon Cooney
355 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 13
Her zaman: 1,235
