Ana içeriğe geç
Olympus Stylus Tough-6000 On/Off Button Replacement
Neye ihtiyacın var
  1. Olympus Stylus Tough-6000 On/Off Button Replacement, Locate On/Off Button.: adım 1, 1 resimden 1.
    • First sit the camera on its bottom. You will be working on the on/off button.
  2. Olympus Stylus Tough-6000 On/Off Button Replacement: adım 2, 1 resimden 1.
    • Place camera upward.
    • You will notice two screws near the on/off button.
    • Use your Phillips #00 screwdriver to unscrew the two screws.
  3. Olympus Stylus Tough-6000 On/Off Button Replacement: adım 3, 1 resimden 1.
    • After unscrewing the two screws near the on/off button you will notice a single screw to your right.
    • Unscrew the single screw with your Phillips #00 screwdriver.
    • This will allow you to pry the panel off.
  4. Olympus Stylus Tough-6000 On/Off Button Replacement: adım 4, 1 resimden 1.
    • Grab your plastic opening tool and start prying off the panel.
  5. Olympus Stylus Tough-6000 On/Off Button Replacement: adım 5, 1 resimden 1.
    • Once the panel is lifted you will want to lift up the cover for the on/off button.
    • The actual on/off button is very small and loose so make sure to be careful with it!
  6. Olympus Stylus Tough-6000 On/Off Button Replacement: adım 6, 1 resimden 1.
    • You have reached the on/off button.
    • You can now replace it!
Sonuç
Bir başkası bu kılavuzu tamamladı.
Shannon Cooney
355 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 600
