Ana içeriğe geç
Olympus Stylus Tough-8010 LCD Screen Component Replacement
Neye ihtiyacın var
  1. Olympus Stylus Tough-8010 LCD Screen Component Replacement, Camera Casing: adım 1, 3 resimden 1. Olympus Stylus Tough-8010 LCD Screen Component Replacement, Camera Casing: adım 1, 3 resimden 2. Olympus Stylus Tough-8010 LCD Screen Component Replacement, Camera Casing: adım 1, 3 resimden 3.
    • Remove the front three screws (3.2mm) using a type T-6 head screwdriver.
    • Take off smaller front cover.
    • Carefully remove larger front cover.
  2. Olympus Stylus Tough-8010 LCD Screen Component Replacement: adım 2, 3 resimden 1. Olympus Stylus Tough-8010 LCD Screen Component Replacement: adım 2, 3 resimden 2. Olympus Stylus Tough-8010 LCD Screen Component Replacement: adım 2, 3 resimden 3.
    • Remove two screws (4.1mm) on the top of the camera using a #000 Phillips head screwdriver.
    • Using a #000 Phillips head screwdriver remove two screws (7.9mm) near the control panel and set aside the metal connector.
    • Although the third photo shows the side panel casing being removed, it is normally secured by a screw under the front framework. You'll need to follow the next two steps to remove the framework and access the screw before you can remove the side casing as shown here.
  3. Olympus Stylus Tough-8010 LCD Screen Component Replacement: adım 3, 3 resimden 1. Olympus Stylus Tough-8010 LCD Screen Component Replacement: adım 3, 3 resimden 2. Olympus Stylus Tough-8010 LCD Screen Component Replacement: adım 3, 3 resimden 3.
    • Using a #000 Philips head screwdriver remove the two screws (4.1mm) on the right side of the camera.
    • Remove two screws (4.1mm) on the bottom of the camera using a #000 head Phillips screwdriver.
    • Remove the single screw (3.2mm) on the front of the camera using a #000 Phillips head.
  4. Olympus Stylus Tough-8010 LCD Screen Component Replacement: adım 4, 2 resimden 1. Olympus Stylus Tough-8010 LCD Screen Component Replacement: adım 4, 2 resimden 2.
    • Carefully remove the font panel piece from the rest of the camera.
    • Carefully remove the top/side plastic piece.
    • If the the camera and flash buttons fall out of their slots set them aside.
    • If you haven't already done so, remove the side casing as mentioned in Step 3. It is secured by a single screw near the bottom corner.
  5. Olympus Stylus Tough-8010 LCD Screen Component Replacement: adım 5, 3 resimden 1. Olympus Stylus Tough-8010 LCD Screen Component Replacement: adım 5, 3 resimden 2. Olympus Stylus Tough-8010 LCD Screen Component Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove four screws (9.4mm) on the front of the camera using a Phillips #000
    • Use the plastic opening tool to release the holding clip.
    • Using tweezers separate the plastic strips from their connectors located on the main circuit board by lifting the small, black flaps on the connectors and pulling on the ribbons.
  6. Olympus Stylus Tough-8010 LCD Screen Component Replacement, LCD Screen Component: adım 6, 1 resimden 1.
    Satın Al
    • Remove all the tape and clear rubber material from the components.
    • Remove two screws (4.1mm) using a #000 Phillips head screwdriver on the left side of the lcd component.
    • Make sure to set aside the two metal pieces that come off after the screws are removed.
    • Using the tweezers disconnect the plastic ribbon from the connector on the control board by lifting the small black flap on the connector and pulling on the ribbon.
  7. Olympus Stylus Tough-8010 LCD Screen Component Replacement: adım 7, 2 resimden 1. Olympus Stylus Tough-8010 LCD Screen Component Replacement: adım 7, 2 resimden 2.
    • Remove all seven screws (4.1mm) from the metal plates (#000)
    • Carefully lift out the lcd screen component from the camera casing.
Sonuç
Luke Visser
476 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 7-15, Williams Spring 2015 Baylor, Team 7-15, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S7G15
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 1,082
