Ana içeriğe geç
Olympus Stylus Tough-8010 Side Panel Replacement
Neye ihtiyacın var
  1. Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: adım 1, 3 resimden 1. Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: adım 1, 3 resimden 2. Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: adım 1, 3 resimden 3.
    • Remove the three screws (3.2mm) from the front panel using a T-6 screwdriver.
    • Take off the smaller front panel cover.
    • Carefully remove the larger front cover.
  2. Olympus Stylus Tough-8010 Side Panel Replacement: adım 2, 3 resimden 1. Olympus Stylus Tough-8010 Side Panel Replacement: adım 2, 3 resimden 2. Olympus Stylus Tough-8010 Side Panel Replacement: adım 2, 3 resimden 3.
    • Remove the top two screws (4.1mm) using a #000 Phillips head screwdriver.
    • Remove the two screws (7.9mm) near the control pad. Set metal connector aside.
    • Remove the side panel casing.
  3. Olympus Stylus Tough-8010 Side Panel Replacement: adım 3, 3 resimden 1. Olympus Stylus Tough-8010 Side Panel Replacement: adım 3, 3 resimden 2. Olympus Stylus Tough-8010 Side Panel Replacement: adım 3, 3 resimden 3.
    • Using a #000 Philips head screwdriver, remove the two screws (4.1mm) on the right side of the camera.
    • Remove the two screws (4.1mm) from the bottom of the camera.
    • Remove the single screw (3.2mm) from the front of the camera.
  4. Olympus Stylus Tough-8010 Side Panel Replacement: adım 4, 2 resimden 1. Olympus Stylus Tough-8010 Side Panel Replacement: adım 4, 2 resimden 2.
    • Carefully remove the front panel piece.
    • Remove the screw (7.9mm) from the bottom left hand corner using a #000 Phillips head screwdriver.
  5. Olympus Stylus Tough-8010 Side Panel Replacement: adım 5, 3 resimden 1. Olympus Stylus Tough-8010 Side Panel Replacement: adım 5, 3 resimden 2. Olympus Stylus Tough-8010 Side Panel Replacement: adım 5, 3 resimden 3.
    • Slightly bend the metal that is covering the side panel axle.
    • Using a paperclip, completely push out the metal bar that holds the side panel to the camera.
    • Remove the side panel door.
Sonuç
James G Payne
225 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 7-15, Williams Spring 2015 Baylor, Team 7-15, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S7G15
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 374
